help with tranny torque arm - JeepForum.com
post #1 of 2 Old 04-01-2010, 07:14 AM Thread Starter
brunolinski
I removed my BA10 and installed an AX15. I am using the Advanced Adapters conversion plate so that I can use my BA10 skid plate. Everything is installed and I have driven it for a few hundred miles with no problems. However, the torque arm is not installed at all. I want to install it and I have acquired all the little pieces that make up the arm (mine was not there when I bought it), but as you can see in the pic, there is nothing for the top end of the torque arm to bolt through. I have seen pics that show a short bar, bolted to the tranny that the upper end of the torque arm should go through.
Anybody have a pic of your Advanced Adapter set up with the torque arm in place? If so PLEASE upload it.
thanks
B
advanced adapter picture by brunolinski - Photobucket
brunolinski is offline
post #2 of 2 Old 04-01-2010, 11:23 AM
moonshinefuel
Are you supposed to use factory torque arm bracket along with the AA adapter plate? Because that's what it kind of lloks like. But I am using a blackberry. So the pic looks small from here.
moonshinefuel is offline
Rebuilt tranny, where to find a good torque converter? Unseenthings YJ Wrangler Technical Forum 5 03-23-2010 06:57 PM
tranny torque arm mount possumwalk YJ Wrangler Technical Forum 6 09-15-2008 04:58 PM
Possible Auto Tranny Torque Converter Issue wack_jeep JK Wrangler Technical Forum 23 05-19-2008 11:20 AM
Torque Specs for 3sp auto tranny pan: FSM hasn't come in yet and have to get it done mexican_hippie TJ Wrangler Technical Forum 3 05-05-2007 05:10 PM
Torque Spec for 2000 Auto Tranny Pan bniedert TJ Wrangler Technical Forum 4 03-23-2007 05:17 PM
