Help! - tranny issues - JeepForum.com
post #1 of 5 Old 03-21-2002, 10:12 AM Thread Starter
rick_chicago
Two unrelated problems:
1. New transmission put in about 40k ago, and the upshift indicator comes on in 5th gear. I assume they didn't connect something properly. Easy fix, or tough one?
2. Reverse lights stay lit when running. I have a slow leak (my guess is slave cyl.) and it has run low before, causing tough shifts. I'm guessing something got stuck during a bout with low fluid. Easy fix, or tough one?
any help is appreciated!
89 YJ 2.5L 5-Spd
rick_chicago is offline
post #2 of 5 Old 03-21-2002, 06:32 PM
jeromy
I would just dissconnect the shift indicator light
I always found them annoying
If you don't know when to shift you shouldn't drive a stick you know what I mean
your reverse switch sounds to be stuck
remove the shiufter boot and play with it
I even had some friends hook em up to toggle switches
And the slave cylinder is a piece of cake
2 bolts and it is off
It just might need bled too
Just follow the line down to the cylinder and you will see an allen bolt (really small one)bleed all the air out of it
or if the seals are really bad and leak you might as well replace it .
They come prefilled just bolt on and go
have fun and good luck man
jeromy is offline
post #3 of 5 Old 03-21-2002, 08:42 PM
JeeperJay
I may be wrong but your YJ might have a internal slave cylinder. If thats the case its a major hassle to replace cause its located on the input shaft of the tranny. That means pulling the tranny to get it off. If you can do it yourself its just time consuming, if not then be prepared to spend a good chunk of cash.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #4 of 5 Old 03-21-2002, 09:21 PM
BigDaddESean
yeah I have to change the slave in my 89 YJ tomorrow or Monday. The tranny has to come down. Good luck man. If you need any tips after I'm done just e-mail me and ask me... bigdaddesean@aol.com This is my first time trying this so I can't tell u till after, and also, whatever I F--- up, I can tell you how not to lol.
Sean's Jeep Page
89YJ. '97 4.0HO, 4" lift, 33" General Grabbers, Header, no cat, glasspack AR rims
BigDaddESean is offline
post #5 of 5 Old 03-22-2002, 09:57 AM Thread Starter
rick_chicago
It's an 89 YJ, 2.5L...
I assume the tranny is a BA 10/5. Am I right on this? Knowing it was replaced, how might I confirm? And everyone's fairly certain it's an internal slave? If so...ugh.
I also have a Haynes at home...should help things a bit.
I'm kicking myself for not paying more attention to the mechanicals when I was younger...gotten better over the years. Live and learn.
89 YJ 2.5L 5-Spd
94 YJ tranny issues Mike-In-Mass YJ Wrangler Technical Forum 20 09-27-2008 05:31 PM
Tranny Issues Tulloh YJ Wrangler Technical Forum 7 11-30-2007 03:27 PM
More Tranny Issues RuskiNYC TJ Wrangler Technical Forum 3 11-17-2006 06:54 AM
Tranny issues ditchdoc TJ Wrangler Technical Forum 3 10-23-2006 06:01 PM
Tranny Issues TellyDSP YJ Wrangler Technical Forum 8 11-04-2003 07:48 AM
