#1 | |
help. t case shifter came off
i went to go into 4 wheel drive the other day and my shifter came off. i pulled off the little metal piece that covers it all and put it back on the fitting but now its just sitting there and will come off if i pull on it. how can i re attach it?
#2 |
from here it gets rough
T-case shifter can be a nuisance because you need to find a part that apparently isn't available any longer. It is called an "isolator" and somehow I managed to get one a year ago. Photos below:
![]() ![]() ![]() It takes up the slack between the metal clip and the Tcase shifter stub. Others have come up with solutions like welding nuts on opposide sides of the shifter and installing set screws, or cutting up pieces of inner tube to function as the isolator.
....I'm not smart, but I can lift heavy things....... Fill out your PROFILE, and don't forget to look in the FAQ for writeups I'm stuck on da Rock http://www2.hawaii.edu/~cbird/Opihi/descrip.htm My Boy Scout Troop site: http://t-304.blogspot.com/ Something bad happened to my photobucket account (..it was my fault...)and all my pictures went blank. I am committed to editing all my writeups and posts to put the photos back in. Let me know if you find a post that needs revision and I will do that one ASAP Currently I believe I have all the critical ones done. |
#3 |
use rubber tape!
I had the same thing happen last week. No problem to fabricate a fix for it though.
I had to replace the spring clip that locks the handle onto the shifter stub. The weld holding the two pieces of spring steel had broken. I wrapped the trasfer case stub with thick Rubbery electrical tape. Not the regular kind of electrical tape, but the thicker and more rubbery kind. Sorry I don't what that typr is called. Anyway, after several laps of that tape on the transfer case stub, position the gear shift handle (with the welded spring steel already inside) over the trasnfer case stub and then push until it all locks into place. Make sure you use enough rubber tape to ensure a VERY tight fir for the transfer case handle. I had to really push hard to get my handle on and now it is great! |
#4 |
I drilled and tapped the outside part with about 8 small set screws (3/16 ?). 2 on each side. I removed all the bad rubber, put the springs back in and put a lot of JB weld in the big part. I then pushed it back into place and tightened the set screws. It has been fine ever since.
91 Wrangler 4.0 5sp 8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
