Help with the shakes! - JeepForum.com
post #1 of 4 Old 07-25-2006, 12:11 AM Thread Starter
younixguru
All,
1994 Jeep wrangler, 100,000 miles. I have owned it since new, never done much to it except for general maintenance. Recenty it started to shake while decelerating, this holds true weather it is in gear or not, and even if the brakes are not applied, just slowing down causes the shake. I checked the U-Joints and they seemed OK. Any thoughts?
Thanks!
Jon
younixguru is offline
post #2 of 4 Old 07-25-2006, 12:15 AM
jipjip
jipjip's Avatar
it could possibly be a weight has fallen off the drive shaft, causing it to be out of balance, but make sure your checking the u-joints while your rig is in neutral and e-brake off, so you can feel the play. otherwise, the trans loads up the drive shaft, and you won't be able to move it even if the joints are bad.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #3 of 4 Old 07-25-2006, 12:58 AM
toke
I_R_Food
toke's Avatar
could be bad rubber on exhaust mounts
Makes mine shake like a mad dog
1995 YJ gone as well
2001 Grand RIP
2004 Rubicon RIP
toke is offline
post #4 of 4 Old 07-25-2006, 01:03 AM
trw
2011 JK Wrangler
also might be the steering stabilizer, although that would shake accelerating or decelerating.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
TJ with the shakes Dalke-cj TJ Wrangler Technical Forum 2 09-30-2008 07:54 AM
Yj shakes J-Rad YJ Wrangler Technical Forum 6 03-20-2008 08:55 PM
Shakes Feigle TJ Wrangler Technical Forum 5 03-15-2007 04:04 PM
got the shakes tat2freke TJ Wrangler Technical Forum 5 11-29-2004 04:14 PM
the shakes Katch TJ Wrangler Technical Forum 8 11-18-2003 10:55 AM
