Help; running hot issues - JeepForum.com
post #1 of 4 Old 03-08-2014, 01:28 PM Thread Starter
Handyf250sdl
1990 YJ, 350 sbc mild built, 160 deg t/stat, Howe 4 core racing radiator w/dual electric fans. On open roads runs about 190 to 200 deg. Idleing or on trails running 220 to 230 & comes up quickly. manual guage which is accurate
Handyf250sdl is offline
post #2 of 4 Old 03-08-2014, 01:34 PM
sig81
did you check the thermostat works? enough fluid
sig81 is offline
post #3 of 4 Old 03-08-2014, 01:43 PM Thread Starter
Handyf250sdl
Yes new stat, had 195 in it & its was worse and coolant is full and circulating. Also has new htr core & all hoses
post #4 of 4 Old 03-08-2014, 05:23 PM
captainauti
are you sure you have a good flow from the water pump? can you check what the difference is between the upper and lower hose for temp?
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
