HELP!!! Replaced Ignition Module, won't run! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > HELP!!! Replaced Ignition Module, won't run!
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-11-2004, 07:04 PM   #1
bidnizman
Hey everybody,
I just replaced my ignition module, and now it will barely start, when it does it idles at an extremely low rpm, i have to keep the gas floored. It seems like the timing is off now? I have no idea. The ignition module i purchased new had different connectors from my stock one, had to chop the connectors of the new module and wire the ones from the old module in. Before i replaced the module it ran fine, started fine, then would just shut off when warmed up. Could i have the wrong module and now its thrown the timing off? PLEASE HELP!!! Stuck in Mexico,
Thanks!
Ryan
'89 Laredo, Rebuilt 4.2L w/4.0 head, Weber carb, Header and Cat-free Flowmaster, Tuffy Stereo Console, 32's..... Love/hate relationship
bidnizman is offline   Reply With Quote Quick reply to this message
Unread 10-11-2004, 09:30 PM   #2
bidnizman
Bump, please help with any ideas...
Unread 10-12-2004, 02:39 AM   #3
Bobbywolf
Seems to me like you received the wrong modual. I just replaced my Igniton modual about a week ago, and the two connectors snapped in place. Works great. Something sounds fishy about having to start splicing things togeather.
Bobbywolf is offline   Reply With Quote Quick reply to this message
Unread 10-12-2004, 11:01 AM   #4
bidnizman
From my research on this board and others, it seems like the replacemente modules can have different plugs and still be the same? I'm not positive. It just seems like something is totally wrong now, it worked better with the old one? I havent replaced the coil yet, could it be something wrong with that now? The problem is worse than when i started.
Unread 10-12-2004, 05:23 PM   #5
bidnizman
Turns out the module i purchased was bad, replaced it with a GOOD new one, fixed the problem. Makes troubleshooting twice as hard when the replacement parts you fix are worse than the current broken parts...
Unread 10-12-2004, 08:24 PM   #6
Bobbywolf
Yikes, good to hear you got her running again though.
