Quantcast help power steering pulley - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > help power steering pulley
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.com
Old 11-30-2006, 06:34 PM   #1
liljoe
i did a motor swap this weekend in my 87 yj i replaced it with a 4.2 and it lookks like thats what i took out . the new motor runs a v belt system which is two belts the old one ran serpatine ineed to change the pulley on the power steering pump it has the serpatine pulley where can i find one i tried all the local parts store nothing please help
liljoe is offline   Reply With Quote
Old 11-30-2006, 06:49 PM   #2
wild_weazel
Probably the only option is a junk yard. Or try the wants board.
1990 Jeep YJ, Olivine Green, SBC 350, 700r4 Tranny, NP231C Transfercase, Painless Wiring, Superlift 3.5" Lift 5/8" M.O.R.E. Shackles, 33" tires. Dana 44's front and rear 4:10 gears, And a Whole lot of Money
wild_weazel is offline   Reply With Quote
Old 11-30-2006, 07:06 PM   #3
Swampwalker3
1987 YJ Wrangler
I have two different sizes from sag pumps. What size are you hunting for?
Swampwalker3 is offline   Reply With Quote
Old 12-01-2006, 05:29 PM   #4
liljoe
i dont know the axact size i have one of the pumps with resvoir built in and i need the pulley for 90 yj factory motor i guess i dont know what size i need to figure out outside dimension or stem shaft please help
Old 12-01-2006, 06:03 PM   #5
Swampwalker3
1987 YJ Wrangler
You probably have the sag pump: Black, looks like canned ham?
Just measure the shaft bore, length. They do make different depths of pullies so you may have to check the local boneyard several times to get it to line up right.
Or hit up advance auto and tell them the year and make of the vehicle that the motor came out of and they can probably ship in a pulley for you.
Old 12-01-2006, 10:18 PM   #6
pyro9862
1. Parts store
2. Junkyard
3. eBay (just buy a used pump with a pulley on it)
pyro9862 is offline   Reply With Quote
Glock Forum
