HELP with power steering - JeepForum.com
post #1 of 4 Old 04-16-2010, 07:31 PM Thread Starter
wordo30
I was on my way to school and once i had gotten there my powersteering went out and i couldn't turn the wheel really easy. Then later that night i took it apart and checked the lines and they seem to be clear of anything that could clog them and then i put everything back together and then i follwed the insructions on how to bleed the system but that didn't work. The power steering works well when im driving it and the RPMs are at 2000 but then whenever i stop or let the RPms go down it gets hard to steer. My setup is a 1990 chevy 350 in a YJ. I am using the chevy pump and the jeep powersteering gearbox. is there some kind of pressure issues that can develop with this system or how can you detect a bad gearbox or bad pump? Please help
wordo30 is offline
post #2 of 4 Old 04-16-2010, 07:36 PM
jay-h
My guess is a bad pump
jay-h is offline
post #3 of 4 Old 04-16-2010, 08:44 PM Thread Starter
wordo30
so you think that the pump is just not feeding enough pressure.
wordo30 is offline
post #4 of 4 Old 04-16-2010, 09:05 PM
burnout189
x2
10char..
BARNHART'S AUTO REPAIR
burnout189 is offline
Slight hitch in steering after power steering gear replacement. chip80 TJ Wrangler Technical Forum 2 10-04-2009 12:49 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
97 wrangler with manual steering, need donor info for power steering. anarchyfor2 TJ Wrangler Technical Forum 7 01-12-2009 07:12 AM
Steering suddenly shudders @ low speed...power steering pump? Please help pinpoint! captndiltz TJ Wrangler Technical Forum 2 08-20-2008 03:23 PM
Power steering pressure line/ power steering belt Ryanjeeper YJ Wrangler Technical Forum 4 11-10-2005 06:10 PM
