Help! Pitman Arm Wont come Off! - JeepForum.com
post #1 of 19 Old 11-06-2013, 08:10 PM Thread Starter
bstubbs11
I have broken 2 arm pullers, gone through a bottle of PB blaster and cut through about 90% with a cut off tool and the stupid thing still will not come off. I do not want to cut any more for fear of hitting the splines and i have been banging on the cut with a chisel for an hour. I don't have access to a torch and obviously don't want to drive it after cutting through it so much. If anyone has any magic tricks on how to get this thing to come off please learn me your ways. Thanks!
bstubbs11 is offline
post #2 of 19 Old 11-06-2013, 08:11 PM
Stud_man50
The only thing I would say would either be a propane or Mapp gas torch, heat and beat is probably the only way. Maybe use the chisel to widen the cut you made.
Stud_man50 is offline
post #3 of 19 Old 11-06-2013, 08:17 PM
jokerchief462
Finish the relief cut or start hitting the relief cut with a good cold chisel. That's how I got mine off.
If you can get enough relief put a puller back on tighten and then use some heat. Just keep your body parts out if the way.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 19 Old 11-06-2013, 08:29 PM
kevinmc
Buy a better puller the cast metal pullers will not work they do not have adequate tensile strength
and if you cut it that could also cause a problem because as you pull on one side it will pinch on the other working against you
kevinmc is offline
post #5 of 19 Old 11-06-2013, 08:29 PM
TSEJEEPERS
Cut it again directly across from the other cut.
Easiest way I have found to take a pitman arm off is.
Put the puller on, place a long bar or pipe on top of the pitman arm, as close to the splines as you can get, one long enough that it sticks out on top of the engine.
Have someone tap on the bar as you tighten the puller.
If you do not have another person tighten the puller, tap on the bar a few times, tighten puller ect.
This has worked for me numerous times.
Even pulling old Waggy pitman arms off.
Remember to leave the nut on a few threads.
When the pitman arms do decide to come off they can come off like a bullet.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 19 Old 11-06-2013, 08:31 PM
turpehar
1977 CJ5
Make a second cut on the other side. I've had to do this a few times. They can be a pecker.
I've been married so long I don't bother looking
both ways before crossing the road.
(Trial + error)*Upgrades) - $ = (mac-n-cheese/hot dogs)+experience
turpehar is offline
post #7 of 19 Old 11-06-2013, 08:33 PM
kevinmc
BTW why are you changing the pittman arm they very seldon ever need to be replaced they are a NON wear part... only real reason to replace it may be if you put in a lift kit
kevinmc is offline
post #8 of 19 Old 11-06-2013, 08:34 PM Thread Starter
bstubbs11
Thanks for the tip on leaving the nut on, that has been in the back of my mind the whole time. I will give all of these a go tomorrow and hopefully the fifth day is a charm. Looks like its back to the store for another puller.
post #9 of 19 Old 11-06-2013, 08:35 PM
kevinmc
BTW why are you changing the pittman arm they very seldom ever need to be replaced they are a NON wear part... only real reason to replace it may be if you put in a lift kit
kevinmc is offline
post #10 of 19 Old 11-06-2013, 08:36 PM Thread Starter
bstubbs11
I am in the middle of installing a 4in lift and will be putting another 1in body lift on next week. I seriously debated not switching out the pittman but after some research i decided with this much lift is was a good idea to switch. Now with the giant cut in it I am to far in to change my mind.
post #11 of 19 Old 11-06-2013, 10:11 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Pittman arms can be a real booger to pull, and when they finally give way, they come off with a BANG! You've done all the right things, PB blaster, heat, etc. At this point, complete the cut thru the arm. If you scuff up or cut some into the splines it will not weaken the steering shaft, nor in any way affect putting on the new arm so long as you dress up the edges of the cut to remove any burrs. I've cut off several that I could not get off with heat, PB, repeated efforts, etc. I don't cut away with total abandon, but cut down gradually til there is very little if anything left holding it together, then put in a thin chisel to spread the cut and they will fall off for you, or at least come off super easy with the puller then. Just complete your cut.
Don't shove on the new one dry, put a little anti-seize on the splines, or some wheel bearing grease. You never know when you may want to pull it off again.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #12 of 19 Old 11-06-2013, 11:28 PM
bill8bud
X2 on this. I went through the same ordeal. i cut mine a little deeper and I hit it with an air chisel to get mine off.
Do the antisieze on the new pitman arm.
bill8bud is offline
post #13 of 19 Old 11-06-2013, 11:32 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Whack the pitman arm with a hammer a few times. Tapered fittings need to be jarred loose
Luck Favours The Prepared
Anticanman is offline
post #14 of 19 Old 11-07-2013, 06:37 AM
Siva283
Get a good puller on it. TIghten it down as tight as you can without breaking the puller. Walk away come back in the morning and pick the pitman arm up off the floor and put the new one on.
Ask me how I know...
Siva283 is offline
post #15 of 19 Old 11-07-2013, 07:10 AM
eajones_01WJ
you want to heat the arm and not the splines and do it fast enough that the splined shaft doesnt expand with it. you have to be careful though because you can melt seals in the steering gear if you let to much heat transfer to it. i had to do mine a year ago and it took me 3 hours to get it off. very frustrating, and the rest of the project, 4 tie rod ends, to me 1 hour. good luck sir!
eajones_01WJ is offline
