HELP! Oil Pressure Switch (elbow connector) - JeepForum.com
post #1 of 4 Old 12-08-2008, 11:21 AM Thread Starter
pacopaco
Hi all,
I'm having a crazy time figuring why the elbow connector from the oil pressure switch to the block is leaking oil, a lot of oil. It's a 5.00 dollar part, and I've already replaced it. Wrapped Teflon tape around the thread.
Anyone have any suggestions ?I'm at a loss.
1995 Jeep Wrangler, 4 Cyl. standard trans. 4WD
pacopaco is offline
post #2 of 4 Old 12-08-2008, 12:07 PM
havasu
On permanent vacation
havasu's Avatar
I'd buy a new elbow, and install it after cleaning up the threads with a tap and die set. That is, as long as you have confirmed the switch itself didn't fail on you.
havasu is offline
post #3 of 4 Old 12-08-2008, 12:45 PM Thread Starter
pacopaco
Thanks havasu,
i did replace the elbow. here's what I'm thinking:
1) I didn't tighten it enough ( though I don't want to overtighten)
2) not enough teflon. I didn't put on any black Silicon, which I think I probably should have.
3) is it posible that the threaded hole expanded? I would think, though, that if it had, somthing else would have gone belly-up before the elbow connector.
The switch itself is fine. that was replaced at the start of this year. the leak is definitely from the contact of the elbow and the block.
pacopaco is offline
post #4 of 4 Old 12-08-2008, 10:40 PM
Felonious_monk
Is it possible that someone tried to tap the hole to accept machine thread?
I'm pretty sure that it is 1/4" NPT thread.....i could be wrong.
Also, I bought a tube of high heat Liquid PTFE. It was real cheap, and is the same thing as teflon tape but liquid. Put the liquid on the male end of the fitting and screw her down tight. Let it sit overnight, and you should be good to go.
Good Luck
Felonious_monk is offline
Oil Leak at the Oil Pressure Sender/Connector SimonTuffGuy YJ Wrangler Technical Forum 2 12-17-2007 06:51 PM
Round connector under airbag switch? greaneyk TJ Wrangler Technical Forum 6 02-09-2006 10:13 AM
Foglamp switch connector TJJP77 TJ Wrangler Technical Forum 8 01-31-2006 08:55 AM
Ignition switch connector YJ 88 pearlwing YJ Wrangler Technical Forum 0 08-25-2005 06:53 AM
Oil Switch...Brass elbow installation i8bugs YJ Wrangler Technical Forum 1 09-24-2004 09:17 PM
