Help! Oil In Airbox! - Page 5 - JeepForum.com
post #61 of 74 Old 10-17-2011, 12:59 PM Thread Starter
bmart
call them again after looking at the link..they said the guy must have misunderstood me ha..its gonna be quite a bit after its all said and done tho
2015 Jeep JK Unlimited Freedom Edition:
Leveling kit with 33" tires
bmart is offline
post #62 of 74 Old 10-17-2011, 01:09 PM
jsawduste
2006 YJ Wrangler
Goggle wheel adapters or check eBay. Several companies out there to choose from.
jsawduste is offline
post #63 of 74 Old 10-17-2011, 05:53 PM Thread Starter
bmart
well more bad news....the oil fill spot..i opened the lid and some smole...could it be the diesel still in there?
bmart is offline
post #64 of 74 Old 10-17-2011, 06:42 PM
jsawduste
2006 YJ Wrangler
Yes most definitely. Do an oil change and get that diesel out of there.
Sorry but IMHO that was a mistake to do. You could of dropped the pan and removed the timing cover and cleaned them up.
post #65 of 74 Old 10-17-2011, 08:38 PM Thread Starter
bmart
was told by grandpa that it would clean it out..he has been a mechanic for many years..i'm changing oil in 50 miles
bmart is offline
post #66 of 74 Old 10-17-2011, 09:09 PM
jsawduste
2006 YJ Wrangler
He may be right about cleaning it out. Leaving all the sludge in the fine mesh screen of the oil pump pick up.....................
post #67 of 74 Old 10-17-2011, 10:37 PM Thread Starter
bmart
what now? u lost me...i scraped out all the sludge with a screwdriver..i didnt just knock it into the oil pan..vaccumn and air hose also got it out
bmart is offline
post #68 of 74 Old 10-18-2011, 03:08 AM
jsawduste
2006 YJ Wrangler
My worry is not what you did with the screwdriver and vacuum. It is with the diesel fuel (a solvent) which may have loosened sludge from other areas of the engine.
That sludge would be thick and gooey. Just like what you cleaned up in the valve cover and head.
The oil pump pickup has a screen in it that could easily get restricted/plugged. Once this happens oil will have a hard time flowing into the oil pump.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_High-Volume-Oil-Pump-Melling_15680021-P_151_R|GRPENGPAMS_1366875530____
At the very least I`d run the engine, keeping on eye on oil pressure and make sure you have flow up through the pushrods into the top end.
Better approach would be to drop the oil pan and clean or replace the oil pump screen.
Your talking about your engines lubrication system here. If the pump cannot pass the oil your bearings are not getting fed.
post #69 of 74 Old 10-18-2011, 07:50 AM Thread Starter
bmart
it suns a tad under 40 while i drive in fifth gear at about 55 sometimes a couple marks below 40..its running pretty good now
bmart is offline
post #70 of 74 Old 10-21-2011, 01:48 PM Thread Starter
bmart
do i need to replace that pump or even mess with it?
bmart is offline
post #71 of 74 Old 10-21-2011, 02:02 PM
oldtime_ironman
I doubt you'll need to replace it, but it would be a good idea to just drop the pan and clean everything out real good, just like the valve cover. You have no idea how much crap can end up in the bottom of an oil pan, especially if you run cleaners and solvents thru the engine... I had almost 4 lbs of gunk once! and it was just like road tar!
oldtime_ironman is offline
post #72 of 74 Old 10-21-2011, 04:26 PM
jsawduste
2006 YJ Wrangler
I am going to disagree with the Ironman on this one.
Your engine has xxx amount of miles on it. You have the pan off to clean everything up. A few more minutes and a little more $$ means you have a new pump. As an added bonus the new pump will come with a new strainer.
You probably could get by with just cleaning the strainer but it is cheap insurance to do it all.
post #73 of 74 Old 10-21-2011, 04:36 PM
oldtime_ironman
Yeah you have a point. I'll have to agree, a new oil pump can't hurt. They don't burn out very often (which is what I really meant), but you may as well as long as you're under there. It's cheap insurance.
post #74 of 74 Old 10-24-2011, 07:10 AM Thread Starter
bmart
ok thanks guys went down the road and when i came back the tires went flat..musta sliced em pretty bad from the looks of it..just my luck
bmart is offline
88 2.5l Oil In Airbox? FSTG60MAN YJ Wrangler Technical Forum 6 09-13-2009 11:34 AM
OEM Airbox ? SuperWade2 TJ Wrangler Technical Forum 7 07-28-2007 09:49 AM
Airbox? Are they the same? onlyn8v TJ Wrangler Technical Forum 2 07-15-2007 08:41 AM
Airbox geabaldyvx YJ Wrangler Technical Forum 21 02-19-2007 08:44 AM
Oil in airbox YJ boy YJ Wrangler Technical Forum 5 02-23-2002 12:15 AM
