Help! Oil In Airbox! - Page 4 - JeepForum.com
post #46 of 74 Old 10-16-2011, 10:13 AM
jsawduste
2006 YJ Wrangler
Take the grommets out of the VC. Push the elbows in the grommets.Push in with the elbows already in the grommets.
Use plenty of lube.
jsawduste is offline
post #47 of 74 Old 10-16-2011, 10:27 AM Thread Starter
bmart
how do the grommets pull out? i tried pulling and yanking and nothin happened...
2015 Jeep JK Unlimited Freedom Edition:
Leveling kit with 33" tires
bmart is offline
post #48 of 74 Old 10-16-2011, 11:26 AM
oldtime_ironman
Use a razor blade and split them into "C" shapes, then use pliers to pull em.
oldtime_ironman is offline
post #49 of 74 Old 10-16-2011, 01:17 PM Thread Starter
bmart
i dont have new grommets tho is the thing
bmart is offline
post #50 of 74 Old 10-16-2011, 02:17 PM
jsawduste
2006 YJ Wrangler
Fold then from the inside. Sometimes a screwdriver from the inside to help them unseat from the lip.
The old grommets are gonna be a PITA to work with as they are dried up and hard. Thought you were using new ones. New ones will be soft and supple. You DO have the elbow with the restricted port for the rear, right ?
post #51 of 74 Old 10-16-2011, 02:38 PM Thread Starter
bmart
they said these came with the grommets but no grommets.... and yes restricted port on rear...gonna c if local part store will get em...darn jeep lol
bmart is offline
post #52 of 74 Old 10-16-2011, 03:26 PM
jsawduste
2006 YJ Wrangler
OK, so you were not able to do the elbows. How about the other vac lines, plastic tree and the line going to the PB booster ?
post #53 of 74 Old 10-16-2011, 03:48 PM
Hollingsheadj
Use plenty of lube.
Life lesson right there.
Hollingsheadj is offline
post #54 of 74 Old 10-16-2011, 03:53 PM
Dallas333
is the rear elbow on the 4 cyl 2.5 supposed to be a restricted port as well?
1999 Chili Pepper Red TJ, 4.0, 5 speed, 4 inch Pro Comp lift.
Disclaimer: We should all have hope and look towards the day where man realizes that the sounds exiting his mouth are mostly complaints and a change occurs. - Chevelle
Dallas333 is offline
post #55 of 74 Old 10-16-2011, 04:57 PM
jsawduste
2006 YJ Wrangler
Honestly I do not know. You might compare part numbers with the 4.0.
Perhaps someone else can answer this, anyone have a good answer to share ?
post #56 of 74 Old 10-16-2011, 10:29 PM Thread Starter
bmart
bought em and they are going on when valve cover goes on..its gonna be runnin hopefully tomorrow
bmart is offline
post #57 of 74 Old 10-16-2011, 10:30 PM Thread Starter
bmart
i almost wanted to say that exact thing hahaha
bmart is offline
post #58 of 74 Old 10-17-2011, 11:25 AM Thread Starter
bmart
got it put back together..ran great then acted like it was out of gas..pulled over and sat for a sec and fired it back up and ran fine...bad gas...but other than that it runs freakin good!!!thanks guys!!!
this is off topic but where can i find wheel adapters? I am buying wheels but they are the 5x5.5 instead of 5x4.5
bmart is offline
post #59 of 74 Old 10-17-2011, 11:46 AM
jsawduste
2006 YJ Wrangler
http://www.spidertrax.com/products/wheel-spacer
post #60 of 74 Old 10-17-2011, 11:56 AM Thread Starter
bmart
just called and they told me that they dont have those is there anyone else? its just my luck
bmart is offline
88 2.5l Oil In Airbox? FSTG60MAN YJ Wrangler Technical Forum 6 09-13-2009 10:34 AM
OEM Airbox ? SuperWade2 TJ Wrangler Technical Forum 7 07-28-2007 08:49 AM
Airbox? Are they the same? onlyn8v TJ Wrangler Technical Forum 2 07-15-2007 07:41 AM
Airbox geabaldyvx YJ Wrangler Technical Forum 21 02-19-2007 07:44 AM
Oil in airbox YJ boy YJ Wrangler Technical Forum 5 02-22-2002 11:15 PM
