Help! Oil In Airbox! - JeepForum.com
post #1 of 74 Old 10-09-2011, 06:30 PM Thread Starter
bmart
I just bought a 1993 jeep yj with six cylinder and five speed off of a family friend. I drove it around a couple blocks and it drove strong and pulled well. It drove amazing on the way home also, but I smelled oil. There was a pretty junky car ahead of me so i thought it was him. I got home and still smelled it. I opened the hood and oil was dripping all over the driver side. I noticed the air box had oil on it so curious, i opened it. There was no filter, and oil in bottom...what is going on? PCV valve? Valve oil returns clogged? Help me out please guys
2015 Jeep JK Unlimited Freedom Edition:
Leveling kit with 33" tires
bmart is offline
post #2 of 74 Old 10-09-2011, 06:41 PM
lilscoot250
On my 2.5l it had a vaccum port on the valve cover that was clogged and it caused my air box to fill up with, i unclogged a year ago and it hasnt done it since. I think the i6 has the same thing
91 YJ 355 camel hump heads performer RPM cam 750 CFM carb 700r4 np231c, 82 cj5 in peices atm its got 4link front and rear 400 SBC full width axles in the process of being redone
lilscoot250 is offline
post #3 of 74 Old 10-09-2011, 06:44 PM
oldtime_ironman
Yep, it happens a lot. The line on the valve cover get clogged. Best thing is to clear them out with solvent and put them back on. Blow through them after you put them on, to make sure they're plenty cleared out. Also make sure you don't have any vacuum leaks - the crank case ventilation needs a good stout vacuum to work properly.
Oh, and welcome to JF, you just found one of the best Jeep sites anywhere!
oldtime_ironman is offline
post #4 of 74 Old 10-09-2011, 06:44 PM Thread Starter
bmart
is that what the pcv valve is?..its got me kinda worried
bmart is offline
post #5 of 74 Old 10-09-2011, 06:46 PM Thread Starter
bmart
what line on the valve cover? any pics i guess? and thanks i always like a good welcoming!
bmart is offline
post #6 of 74 Old 10-09-2011, 06:48 PM
moonshinefuel
Yours has no pcv valve. It has this;
Closed Crankcase Ventilation (CCV): A system in which crankcase vapors are discharged into the engine intake system (usually via the intake manifold) where they are burned during the combustion process rather than being discharged into the atmosphere.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #7 of 74 Old 10-09-2011, 06:51 PM
lilscoot250
It should be just a random vaccum line going into the valve cover on mine it is copper colored and it just unscrews from the valve cover
post #8 of 74 Old 10-09-2011, 06:51 PM Thread Starter
bmart
local parts store found it in the system...but what is the ccv? should i be worried at all guys...im new to the jeep thing but i know if a diesel does tht it is a bad bad day
bmart is offline
post #9 of 74 Old 10-09-2011, 06:52 PM
wendell
1987 YJ Wrangler
I forget the exact in and outs, but the 4.0 is noted for this when they get some age on them. The fix was to replace all the plastic lines conected to the valve cover, pc valve and to clean out the valve cover it's self. I use to have the part numbers for the replacement line kits when I had my jeep comanche with a 4.0 that had the same problem a few years ago. I'm sorry I couldn't be more help, but just wanted you to know that it isn't a big deal. Some of the lines get clogged after time and what not and it cause's back presure that pushes oil into places that it shouldn't. I remember that there were 2 kits that replaced all the plastic lines that cause the problem and you could still get them from jeep, plus a good scrubbing of the valve cover. Some one else may have more detailed info for you. However, don't panic, it's just a 4.0 thing that can be easily fixed.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #10 of 74 Old 10-09-2011, 06:58 PM Thread Starter
bmart
any one have those part numbers? i wanna take it out as soon as possible...im afraid to drive it now
bmart is offline
post #11 of 74 Old 10-09-2011, 07:00 PM
lilscoot250
Its no big deal at all i have put 40k miles on mine since i cleaned it out running back and fourth from ks to tx and no problom every 3k miles i have only burnt .5 a quart or so on a 2.5 with 165k on it
post #12 of 74 Old 10-09-2011, 07:04 PM Thread Starter
bmart
i prolly shouldn't drive it now should i? i only got to drive it a whole 20 min..and now she is parked.....
bmart is offline
post #13 of 74 Old 10-09-2011, 07:06 PM
lilscoot250
Takes 5 min to clean the vaccum port then your back on the road
post #14 of 74 Old 10-09-2011, 07:11 PM Thread Starter
bmart
seriously? dang...i'll go to the license branch tomorrow and it'll be on the road....what all does that involve...also should i go ahead and replace my hoses and stuff? i got a good enough deal i can put some money into it
bmart is offline
post #15 of 74 Old 10-09-2011, 07:30 PM
lilscoot250
I didn't need to replace any lines on mine they were all still good, it was just clogged but mine was a texas jeep i dont know the condition of your hoses if your hoses are brittle then i would replace them for preventative maintanance save you trouble down the road. But if the hoses are in condition then i wouldnt im a big beleiver in not fixxing something that aimt broke.
88 2.5l Oil In Airbox? FSTG60MAN YJ Wrangler Technical Forum 6 09-13-2009 10:34 AM
OEM Airbox ? SuperWade2 TJ Wrangler Technical Forum 7 07-28-2007 08:49 AM
Airbox? Are they the same? onlyn8v TJ Wrangler Technical Forum 2 07-15-2007 07:41 AM
Airbox geabaldyvx YJ Wrangler Technical Forum 21 02-19-2007 07:44 AM
Oil in airbox YJ boy YJ Wrangler Technical Forum 5 02-22-2002 11:15 PM
