Help with non tilt steering column - JeepForum.com
post #1 of 6 Old 08-29-2013, 11:37 AM Thread Starter
Adamgl
1987 YJ Wrangler
I'm trying to fix my 87's non tilt steering column.
How do I get this plastic piece off in the pics?
I have all the bolts and hazard light switch, turn signal arm and switch, ignition cylinder removed. Do I just pull and pry harder?
I don't want to break the plastic.
Adamgl is offline
post #2 of 6 Old 08-29-2013, 01:37 PM
SeanB95YJ
in that last pic, I can still see 3 torx head screws.... did you remove those?
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 6 Old 08-29-2013, 01:48 PM
jbolty
jbolty's Avatar
This is info on the tilt, but the upper part is the same.
http://www.crankshaftcoalition.com/w...ck_Rebuild.pdf
jbolty is offline
post #4 of 6 Old 08-29-2013, 02:02 PM Thread Starter
Adamgl
1987 YJ Wrangler
Those are just pics from another tilt writeup. Mine has 4 hex head bolts that I removed.
Adamgl is offline
post #5 of 6 Old 08-29-2013, 02:42 PM
tdewit
tdewit is offline
post #6 of 6 Old 08-30-2013, 07:18 AM Thread Starter
Adamgl
1987 YJ Wrangler
Now I can say the non tilt is way different from the tilt. I just pried on it till it broke free. (and broke all the hidden mounting screws) Turns out on the non tilt that part is screwed on from the back.
So on a non tilt you would have to take the entire plastic assembly off, then unscrew the front piece, to get to the internals.
Now I need to buy a new steering column sleeve, lol.
Adamgl is offline
