HELP! NO SPARK GOING INTO IGNITION COIL what could it be?! - Page 3 - JeepForum.com
post #31 of 45 Old 03-09-2013, 10:31 AM Thread Starter
DAjeep88
Originally Posted by vadslram View Post
But there are spliced wires at the solenoid? Like I said our rigs have a long and storied past when it comes to POs.
I scanned in the ignition schematic and some trouble shooting pages from my factory manual.
Try these.
http://home.mindspring.com/~dave.mcd...20ignition.pdf
Thank you! You went above and beyond! Im going to trouble shoot it today...one more question are there any fuses that I have to worry about?
DAjeep88 is offline
post #32 of 45 Old 03-09-2013, 11:16 AM
vadslram
I don't believe so.
vadslram is offline
post #33 of 45 Old 03-09-2013, 12:47 PM
Que89YJ
Fuseable links on the firewall starter solinoid.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #34 of 45 Old 03-09-2013, 01:34 PM Thread Starter
DAjeep88
Are they the black and red square box fuses on the passanger side of the firewall?
DAjeep88 is offline
post #35 of 45 Old 03-09-2013, 04:16 PM Thread Starter
DAjeep88
Alright guys so I connected the ignition coil straight to the battery and the jeep started so I know my ignition coil is good so where is my problem! ????
DAjeep88 is offline
post #36 of 45 Old 03-09-2013, 06:02 PM
Old4X
1990 CJ7
Power lead from ICM to coil. Goes to relay under battery, then to coil IIRC. Check your wiring diagram
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #37 of 45 Old 03-09-2013, 06:17 PM
Que89YJ
It comes off the resistive write from the alternator. In my post I ask for 2 measurements.
Fault codes:
No Start:
Que89YJ is offline
post #38 of 45 Old 03-09-2013, 07:26 PM
Old4X
1990 CJ7
http://home.sprynet.com/~dale02/wire-big.png Your hot lead has 2 power sources, one straight battery voltage in "start" and the other via the resistor wire shown in red.
Are you using this wiring diagram?
No part of my ignition circuit has anything to do with the alternator.
Old4X is offline
post #39 of 45 Old 03-10-2013, 08:42 PM Thread Starter
DAjeep88
Yes I am so what do you think went bad?
DAjeep88 is offline
post #40 of 45 Old 03-11-2013, 04:32 AM
Old4X
1990 CJ7
Take your multimeter and check the white wire at the ICM with key in start condition.
Check red wire at ICM in run condition. DO NOT leave in run position with engine off for more than a few seconds, else you will burn up your ICM.
Old4X is offline
post #41 of 45 Old 03-11-2013, 09:25 AM
psyco31
i had a similar issue like this when i put a 4.0L form a 99 XJ into my 89 YJ. i spent three days trying to trouble shoot everything. come to find out it was a mini fuse in the fuse box under the hood that shuts off the ingnition system if it was blown. I learned real quick check every fuse no matter what it was for. I don't know on the 88 if you have a fuse that may do the same thing. Soinds so simple, but i tried everything you have been trying before i figured that out.
psyco31 is offline
post #42 of 45 Old 03-11-2013, 09:56 AM
Old4X
1990 CJ7
Also, do not run straight battery power to coil for very long. Yes, it will run, but the resistor in the normal wiring is to keep from frying your coil.
The start circuit uses full battery voltage to coil, then switches to power through the ballast resistor in run (drops voltage to 8 volts or so).
There are ignition mods that do allow full voltage to coil, as more modern ICMs are internally regulated. I have this setup using a GM ICM from a Chevy V-8.
Old4X is offline
post #43 of 45 Old 03-11-2013, 10:40 AM
Que89YJ
DA when you start the jeep it has a path that gives it 12 vdc. When you release the starter it is switched through the resisve wire and drops down the coil voltage to about 8 vdc. In the link is the service manual. Use the 1990 trouble shooting step by step starting at page 117.
http://www.jeepforum.com/forum/f12/c...block-1400388/
Que89YJ is offline
post #44 of 45 Old 03-16-2013, 01:58 PM Thread Starter
DAjeep88
So guys thanks for all the help it ended up being my starter relay it was 40 bucks and she started right up!
DAjeep88 is offline
post #45 of 45 Old 03-16-2013, 02:34 PM
Que89YJ
Did you use the procedure in the fsm?
Fault codes:
No Start:
Que89YJ is offline
help needed , ignition , ignition coil , no spark
