Help. Newbie. Clunking noise. Am i getting ripped off - Page 4 - JeepForum.com
post #46 of 49 Old 04-02-2013, 06:50 AM
soonermatt
Originally Posted by ato500 View Post
well after some good advice from all of you and some research, I had to say goodbye to my 35's. I love the look but just doesn't seem like a smart idea, unless I like to throw money in the toilet. went to a 32x11 maxxis bighorn tire on d-window rims. also swapped rear end out of another YJ and that is working perfect.. now onto trans. I have an ax-5 and 1st and 2nd are toast.. there is one close by that 1st-4th is good but 5th is out, mine had same issue when I bought the jeep.. question is, can I get his trans and have 5th swapped from mine into his to have 1 unit working correctly, or is that a waste of time? thanks for the help
In my opinion, you could PM MeanMax to get the best answer on the forum. He's a pretty good expert on this exact issue. I think he wrote the stickies describe the process you would use to fix and swap the gears if you had the bearing splitter and presses.
soonermatt is offline
post #47 of 49 Old 04-02-2013, 02:05 PM
RockShoxTora
Hi, thanks in advance for the help. I have a 89 YJ with a 4in rough country suspension lift and 35/12/15 mickeys. Had lift put on at local mechanic ( I'm not mechanically inclined). He missed a bolt or two doing the lift so I don't have a ton of confidence in him. He also fixed 5th gear and put in a clutch, all in fall of 2012. Took jeep in some mild mud a few weeks ago and heard clunking noise in 4wd. Left mud and parked it at home. 2wd worked fine at the time. I assumed ubolt and he thought same. When driving to mechanic, clunking got worse, only hear it when slowing down and sometimes it continued for a second or two after stopping. Also just at this point it was real hard to get in gear, had to grind to get in sometimes. He checked it out but said needs new rear end ( I know stock yj rear is junk, especially w big tires) and said transmission needs to be replaced. Does this sound right?? Also, what steps should I take if this is right, I'd rather upgrade rear end etc so it doesn't happen again. Thanks for your help.
I hate to break it to you, but it sounds to me like a transmission problem. Your rear-end might not be far behind.
I bought a remanned AX-5 for my rig for 700 back when I first bought the Jeep. The thing nuked on me about 15k miles later while I was on the highway in 4th. It wouldn't shift into any other gear than 4th, and it clunked horrendously.
Prior to the tranny going, I heard faint clicks in my tranny when driving under 35.
Your rear-end is probably temporarily salvageable. He probably cracked it open and found broken teeth on your spider gears. These can be replaced by yourself for $50 if you know where to look. I've been driving with breaking spider gears for almost a year. It's a ticking time-bomb, but I don't drive it hard anymore.
Long story short, I would advise you to upgrade if you are running 35s.
If money is tight, have a reputable shop in your area rebuild your transmission. I got a transmission rebuild almost 40k miles ago and things run great.
Also, replace your tranny fluid once a year. When my AX5 is ready for a fresh change, 2nd starts to grind when shifting. It's just a friendly way my rig reminds me to take care of it
1995 YJ
-3.5" Black Diamond Suspension Lift, Skyjacker Hydro 7000s
-1.25" Body Lift
-Trail-Gear Bumper and Tire Swing-Out
-31" BFG M/Ts KM
Square Headlights Member #751
RockShoxTora is offline
post #48 of 49 Old 04-02-2013, 07:12 PM Thread Starter
ato500
Rockshoxtora, Thanks for the reply. you are right, it was a rear and and tranny problem. rear end had chunks of teeth out, luckily I found someone with a rear end I got for a pretty good price and that's already installed and working well. Trans getting fixed this weekend or next week. I hate the look of the 32" tires compared to the 35" but I know its good for the long run.
ato500 is offline
post #49 of 49 Old 04-03-2013, 11:47 PM
RockShoxTora
Good deal. The chipped teeth I'm guessing were the spider gears. You didn't buy another D35 did you?
And the AX5 is a fine tranny as long as you take good care of it. Remember, replace the fluid often and don't pop the clutch running 35s.
I'm running 32s with a 3.5" suspension and 1 inch body lift. I also trimmed the fenders ever so slightly. I honestly think it fills the wheel wells out nicely. Also still push 15 mpg. The best feature is I get FULL articulation. I can flex out with coming close to my fenders.
Here's a pic of my rig. It might help persuade you. Plus 35's will sell like hot cakes on craigslist.
Cheers mate!
1995 YJ
-1.25" Body Lift
-31" BFG M/Ts KM
