Help needed 2.5L stumbling and back fireing with surging, INTERMITTENT PROBLEM - JeepForum.com
post #1 of 11 Old 05-29-2009, 07:24 PM Thread Starter
Bojeepus
OK I have a problem but I have no clue were to start, its one of those intermittent problem, sensor maybe?? Any way its a 2.5L 1995 190,00 miles, as IM driving it will start surging and then stumbling and backfiring over and over, I can throttle through it but as soon as I let off it starts again, and then after I stop and start going again, it may not do it, could it be the fuel filter, fuel pump, sensor, I just did a tune up a few months ago and I have only put a few thousand on it and yes I used quality parts, IM just not sure were to start or what it could be any ideas on were to start and what it could be would be greatly appreciated and again its a problem that comes and goes
Bojeepus is offline
post #2 of 11 Old 05-29-2009, 08:02 PM
Carolinarednek
1978 CJ7
Mine was doing the same thing. I dropped the fuel tank and cleaned it out and replaced the fuel pump sock. Hasn't acted up since. That was 3 weeks ago.
1978 CJ7 304 V8 3spd. Renegade
/_ l__\____\
l --\__l----olllllo--
(o))-o-(o))-o-(o))
Carolinarednek is offline
post #3 of 11 Old 05-29-2009, 09:02 PM Thread Starter
Bojeepus
thanks i was thinking fuel pump or stoped up fuel filter but wasn't sure as it was comeing and going
Bojeepus is offline
post #4 of 11 Old 05-30-2009, 04:45 AM
rykerjenbob
How about the catalytic converter?
rykerjenbob is offline
post #5 of 11 Old 05-31-2009, 08:21 AM Thread Starter
Bojeepus
the cats in good shape i replaced that not so long ago when the factory one blew apart
Bojeepus is offline
post #6 of 11 Old 05-31-2009, 05:30 PM
Bigboyky
Mine did that but only when raining ir water on the road. Ended up being the O2 sensor. My son's was doing it all the time after warmed up.... That was the fuel line, where it goes from steel to rubber. The rubber was rotten and soft. Hope this helps some.
1995 4.0l, 5spd., 4:88's, ARB's F/R, 4"RC lift, homebrew bumpers & tire carrier, homebrew gas tank skid, lined inside, Cobra cb, smitty winch, 130w & 55w Hella lights
Envy our past, Fear our future Go Cats!
Take a look at our club
& here on JF
Bigboyky is offline
post #7 of 11 Old 05-31-2009, 08:11 PM Thread Starter
Bojeepus
thanks i'll keep that in mind
Bojeepus is offline
post #8 of 11 Old 06-02-2009, 01:22 PM Thread Starter
Bojeepus
ok i droped the tank and after i the sending unit/fuel pump, i found metal shavings under it, so i guess its the pump for sure
Bojeepus is offline
post #9 of 11 Old 06-15-2009, 11:01 PM Thread Starter
Bojeepus
so now that i got every thing back in and have been running around for 2 weeks all is well it was the fuel pump, my jeep seems to be running better all the way around thanks for the help
Bojeepus is offline
post #10 of 11 Old 06-16-2009, 04:27 AM
YJInterceptor
I just replaced my fuel pump and fuel pressure reg as well, and I can't help but keep thinking that it feels differently for some reason. Felt like it had more power before the swap, well, before the death of the old pump anyway. I think its just me though, or that hole in the muffler that I found.
YJInterceptor is offline
post #11 of 11 Old 06-17-2009, 08:08 PM Thread Starter
Bojeepus
ya im feeling the same way now thats its done ive cherped the the 33s a few times
Bojeepus is offline
1990 2.5 surging problem at 2000 rpm 24vtd YJ Wrangler Technical Forum 3 03-22-2009 04:24 PM
surging idle and surging throttle on warmed freshly turned on engine ChaosMTB TJ Wrangler Technical Forum 2 04-08-2008 08:21 AM
Engine surging problem. 00 TJ 4.0L imprtfightr TJ Wrangler Technical Forum 3 05-11-2007 08:16 AM
Surging problem 50th YJ Wrangler Technical Forum 3 10-25-2004 09:34 PM
Please help solve surging problem. GOTMEAT TJ Wrangler Technical Forum 2 08-05-2003 01:26 PM
