Help! My Speedometer Stopped Working and Check Engine Light is On Too - Page 2 - JeepForum.com
post #16 of 23 Old 08-02-2008, 07:03 PM Thread Starter
95GreenWrangler
Originally Posted by Ringwood View Post
Remove the dash panel and take out the bulb under the check engine light and go get it inspected. After you get it inspected put the bulb back in.
Yes that is what my friend told me, apparently that works for his Jeep but he also has no computer whatsoever in his Jeep anyways.
1995 Green Jeep Wrangler
95GreenWrangler is offline
post #17 of 23 Old 08-02-2008, 07:04 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
My FSM say that the WHT/OR wire on pin 1 of the VSS goes to pin #47 of the PCM
Then the BLK/LIGHTBL wire on pin 2 goes to a splice in the wiring harness located above your distribute cap and it eventually provides a ground for several sensors and goes to pin 4 of you PCM.
The last wire is on pin 3 and is Orange. It goes to a splice that is just above yoyr brake booster that eventually goe to the PCM and gets 8Volt feed to the sensors that are common with this VSS. They are the crank sensor and the cam sensor
Last edited by laybackman; 08-02-2008 at 07:10 PM. Reason: color change and more informaiton
laybackman is offline
post #18 of 23 Old 08-02-2008, 10:26 PM Thread Starter
95GreenWrangler
Originally Posted by TSEJEEPERS View Post
Again as I posted before does your Jeep die when you come to a stop?
If it does that would say it is in your speedo. It could even be internal. You may need to pull the gear out of the output of the transfer case and see if your gear is shot. They are just plastic and I would imagine over time it could get brittle and break.
Heck take it to the inspections and see what they say. If they fail it they may be able to give you some insight as to why it failed and what to do about it.
Your check engine light coming on tells you it is a sensor, you may need to take it some where and have them read the code. Try Auto Zone, not sure if their readers will work but it is worth a shot.
Nope Jeep doesn't die when I come to a stop. Yea I only checked to see if the speedo was actually attached, not if it was dead or not (not sure how I would know). Yea I have read the code and it doesn't make sense for what my engine is... code 36.
post #19 of 23 Old 08-04-2008, 11:22 AM Thread Starter
95GreenWrangler
I'm not sure if it has been suggested, but is there any way this could have been because of a blown fuse? I would wonder if the speedometer even has a fuse, does anyone know this? I will check when I get home, I'm just at work now without my Hanyes. Just a shot in the dark...
post #20 of 23 Old 09-09-2008, 05:04 PM
BorderC
1991 XJ Cherokee
My jeep has the same problem. The speedometer sometimes works but eventually will stop working and the check engine light will comes on. And I get the code# 36 as well
Its not a big deal for me because I have a Garmin GPS that gives me my speed so I just watch that when I need to. But the check engine light coming on is annoying.
'91 Cherokee Laredo 4.0 H.O. - RE 3.5" Superflex Lift - 32x11.50R15 BFG Mud-Terrain KM2
I may sound calm, but in my head I've killed you three times.
BorderC is offline
post #21 of 23 Old 11-11-2008, 08:06 AM
Kman1983
1983 CJ5
On my wifes '93 the speedo will stop working and the check engine light will come on and it will start running like crap and soon die. After it sets a few moments it will start and run fine for maybe a few minutes or maybe a few days?????
Kman1983 is offline
post #22 of 23 Old 04-22-2010, 04:32 PM
speedy2954
1991 MJ Comanche
Codes
instead of it being 36 try 3,6,55
speedy2954 is offline
post #23 of 23 Old 04-22-2010, 05:08 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I think the codes were 12 & 15 then you sould have gotten a code 55.
First one says your battery has recently been disconnected. The next code concerns your VSS sensor. The last code is saying The End.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
Speedometer stopped working MaxPower49 TJ Wrangler Technical Forum 0 09-25-2009 07:01 PM
Check Engine Light Not Working dcmielec YJ Wrangler Technical Forum 2 08-10-2009 07:03 PM
Speedometer stopped working Jay_NH92 YJ Wrangler Technical Forum 3 07-01-2009 06:01 AM
Speedometer stopped working....... NewhampshireYJ YJ Wrangler Technical Forum 1 01-01-2008 08:46 PM
Check engine light/ speedometer yamar18 TJ Wrangler Technical Forum 1 09-27-2007 12:30 PM
