help with my 87 wrangler Jeep YJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > help with my 87 wrangler Jeep YJ
Bds fox ipf 2.0 racing series shocks now available at rockThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 07-15-2015, 03:50 PM   #1
jerseygirl0820
1987 LJ Wrangler
so i bought this jeep and although people say its ugly or a bad choice i love it. This am i was doing a k turn and it stalled mid way thru. so in the middle of the street .. paniced ... it started right up no issue,, but when i go to reverse it shuts off. weird if you held the brake and gassed it you could get it to stay on..
last weekend i had it out no real issues, except that its started bogging after 45 miles an hour - ike it wants to go but does .. i am hoping its not any major .. thinking
tourque convertor, fuel pump or maybe something electrical
does anyone know if the tranny has an electrical celenoid in this 1987 wrangler - YJ 6 cycl.
appreciate your help
jerseygirl0820 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2015, 08:52 PM   #2
jimbos76cj
Do you know what your idle is when it's in gear? Could be that it's set to low and causing it to stall under the load in reverse. There's a few things you can do to help make it run better but I know NJ inspection is rough (grew up in trenton). If you don't have a tach Google 87 yj idle speed adjustemt or screw and try adjusting it up alittle. The carbs on the 87-91 are know for going bad pretty easily.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 05:09 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
How old is the gas filter? They are only good for a year or so on a daily driver. Be sure it sits level with the return line at 12:00.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 07:01 AM   #4
Que89YJ
No solenoid. Are you ok with turning a wrench on your vehicle? Do you have to comply with emissions test?
Que89YJ is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 07:30 AM   #5
mike134
Someone thinks the YJ is ugly?
mike134 is online now   Reply With Quote Quick reply to this message
Unread 07-16-2015, 08:19 AM   #6
Que89YJ
She gets it.
Unread 07-16-2015, 08:37 AM   #7
mike134
As people help you through your repair troubles, post pictures of your jeep and we will tell you what an awesome correct choice you made in vehicles.
Also, the jeepforum is very good at diagnosing YJ problems. If you need your vehicle fixed right away to get to work, then take it to a shop. If you want to save a lot of money, or if you just WANT to do it yourself, the jeepforum members will work you through it, but since it is an internet forum, it can take a while to run a suggested diagnostic, then come back with the results, then get the next test to run, repeat, etc.
