Help with my 1987 wrangler - Page 4 - JeepForum.com
post #46 of 54 Old 09-21-2013, 09:45 PM
Que89YJ
Great news! I hope that was it!
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #47 of 54 Old 09-22-2013, 08:36 AM Thread Starter
Alphasolder
1987 YJ Wrangler
Okay this morning she tried to start but I had to put carb cleaner in her to start her ??? So now I have to figure that out any ideas on that would be helpful I'm going to search to see if I can find info but the good news is she's trying now and she's still running once I put the carb cleaner in her. I even started her back up she fired right up without the carb cleaner
Alphasolder is offline
post #48 of 54 Old 09-22-2013, 08:49 AM
Que89YJ
It sounds like the float needle valve it's not sealing the bowl and you are leaking the fuel back from the carb.
Fault codes:
No Start:
Que89YJ is offline
post #49 of 54 Old 09-22-2013, 09:00 AM
JHo303
1987 YJ Wrangler
Did this jeep run well at any time during these posts?
JHo303 is offline
post #50 of 54 Old 09-22-2013, 06:19 PM Thread Starter
Alphasolder
1987 YJ Wrangler
Yes it's just the first time you go to start her you have to use carb cleaner I played with the choke today now its running ****ty so I need to play with the choke tomorrow it's not opening fast enough
post #51 of 54 Old 09-22-2013, 06:21 PM Thread Starter
Alphasolder
1987 YJ Wrangler
How do you fix this?
post #52 of 54 Old 09-23-2013, 06:15 AM
Que89YJ
I am not a carb guy but I know enough to be dangerous. There is a bunch of threads on the carter carb both in the CJ and YJ sections that cover it. The google search is your friend. This is the way to use google to narrow down the search:
http://www.jeepforum.com/forum/f12/f...oogle-1003734/
And here is what you get:
https://www.google.com/search?hl=en&...le&safe=active
Please note that I was interested in the CJ and YJ sections so I removed the f12 on the end of the search and searched the entire forum. I hope it helps.
Que89YJ is offline
post #53 of 54 Old 09-23-2013, 08:19 AM
rocketboy
rocketboy's Avatar
I am not a crab guy but I know enough to be dangerous. There is a bunch of threads on the carter carb both in the CJ and YJ sections that cover it. The google search is your friend. This is the way to use google to narrow down the search:
I'm not normally a crab guy but I haven't got much sleep this weekend. I'm pretty crabby
rocketboy is offline
post #54 of 54 Old 09-23-2013, 09:01 AM
Que89YJ
LOL noted and fixed!
Que89YJ is offline
