Help with my 1987 wrangler - Page 2 - JeepForum.com
post #16 of 54 Old 09-15-2013, 07:43 AM
jbolty
jbolty's Avatar
Let's go back to the beginning.
Was it running?
What changed?
Fuel, air, compression, spark - testing for each of those?
jbolty is offline
post #17 of 54 Old 09-15-2013, 07:45 AM
holliewood61
1981 CJ7
leaking intake gasket will make it run like crap. if you can get it running take some brake cleaner and spray it around where the intake bolts to the head. if it is leaking you will notice a change in the sound of the engine. if its leaking bad enough it will not run.
holliewood61 is offline
post #18 of 54 Old 09-15-2013, 08:06 AM
jbolty
jbolty's Avatar
All three threads all merged
jbolty is offline
post #19 of 54 Old 09-15-2013, 08:09 AM
jbolty
jbolty's Avatar
Originally Posted by Alphasolder View Post
As some of you may remember I was here with emissions problem. still haven't passed emissions but the big issue now is it won't stay running and has trouble starting it is getting gas this problem is progressively worse I went and picked it up from mechanic shop and they have no idea what it could be. So here's what I've done
Spark plugs
Coil
New carb a carter
Starter solenoid
Fuel filter
Fuel pump
O2sensor
Cat
Cleaned engine out of carbon
Changed gears from 456 to 373
Added downdraft pulse air system to get a waiver
Changed oil
I looked at the ICm today cleaned it off put it back on
None of this has helped the stalling and the starting issue please help I'm out of money to take it to the shop
Did you take this to a mechanic or just some guy that owns a wrench?
Throwing parts at a problem without a proper diagnosis is just plain theft if it's at a proper garage.
What do the gears have to do with stalling?
jbolty is offline
post #20 of 54 Old 09-15-2013, 01:01 PM
rocketboy
rocketboy's Avatar
I think someone told him to change his gears to help with emissions since they run it on a dynamometer.
___________________
1989 YJ - 4.0L
2001 WJ 4.0L
rocketboy is online now
post #21 of 54 Old 09-15-2013, 03:56 PM Thread Starter
Alphasolder
1987 YJ Wrangler
I know I spent a lot already kinda turns my stomach especially to no avail I was kind of hoping I had a cps that would explain all the dying and hard starting I disconnected the ignition module cleaned up the plugs and put it back on maybe ill take it off and see if checkers or auto zone will check it out for me
Alphasolder is offline
post #22 of 54 Old 09-15-2013, 08:54 PM Thread Starter
Alphasolder
1987 YJ Wrangler
The jeep was running it would die every now and then. Then I took it to the mechanic when it didn't pass emissions. He was a certified mechanic. The jeep started getting worse after a new carb and when they changed the vacuum.its never been the same. It never did pass emissions. They told me to change the gears because it was making the motor work harder and they thought that could be why I wasn't passing.now the jeep dies every time I start it and it takes longer to get started. I know it's getting fuel I can smell that. So I'm going to check the grounds and the spark plugs make sure there gapped good. But I don't know what's next to try someone mentioned the ICm so ill take that back out then take it down to get tested will let you all know what happening any ideas are appreciated
post #23 of 54 Old 09-16-2013, 04:56 AM
superj
sounds like the carb is set to rich and it is flooding the engine
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #24 of 54 Old 09-16-2013, 06:49 AM
CBinDC
The OEM ICMs are known to be poor quality, they die all the time. I've been through 2 in the past year. This can definitely create starting problems.
If you're running too rich, pull the plugs and see what color they are. If black, then you are running rich. There's a great photo chart floating around the Internet that shows what color your plugs should be and what could be wrong if they a different shade. I don't have it on hand so I can't share it.
CBinDC is offline
post #25 of 54 Old 09-16-2013, 11:03 AM
jokerchief462
Google is your friend type in Spark Plug Reading and the picture shows up.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #26 of 54 Old 09-16-2013, 12:25 PM
jbolty
jbolty's Avatar
Sounds to me like this so-called mechanic is taking you for a ride. Did you really go from 4:56 gears to 3:73 or was it the other way around?
jbolty is offline
post #27 of 54 Old 09-16-2013, 12:37 PM
CBinDC
Originally Posted by jokerchief462
google is your friend type in spark plug reading and the picture shows up.
Sent from underneath my jeep
+1
CBinDC is offline
post #28 of 54 Old 09-16-2013, 04:42 PM Thread Starter
Alphasolder
1987 YJ Wrangler
Yes I gave up the 456 gears and went to 373s still trying everything else will let you guys know
post #29 of 54 Old 09-19-2013, 06:03 PM Thread Starter
Alphasolder
1987 YJ Wrangler
Okay took the ICm off got it tested was bad replaced that and the distributer cap and rotor and it still just turns doesn't start I have spark at the coil I know the spark plugs wires are probally old but wouldn't the jeep still start but run crappy? I haven't pulled the spark plugs to see the color yet will do tomorrow what else can it be?
post #30 of 54 Old 09-20-2013, 08:49 AM
Que89YJ
You need to check spark at the plugs.
Que89YJ is offline
