Help with my 1987 wrangler - JeepForum.com
post #1 of 54 Old 09-08-2013, 07:58 PM Thread Starter
Alphasolder
1987 YJ Wrangler
As some of you may remember I was here with emissions problem. still haven't passed emissions but the big issue now is it won't stay running and has trouble starting it is getting gas this problem is progressively worse I went and picked it up from mechanic shop and they have no idea what it could be. So here's what I've done
Spark plugs
Coil
New carb a carter
Starter solenoid
Fuel filter
Fuel pump
O2sensor
Cat
Cleaned engine out of carbon
Changed gears from 456 to 373
Added downdraft pulse air system to get a waiver
Changed oil
I looked at the ICm today cleaned it off put it back on
None of this has helped the stalling and the starting issue please help I'm out of money to take it to the shop
Alphasolder is offline
post #2 of 54 Old 09-08-2013, 07:59 PM Thread Starter
Alphasolder
1987 YJ Wrangler
So forgot to tell you I have the 4.2 motor
post #3 of 54 Old 09-08-2013, 08:05 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
When I bought my YJ it would not idle on its own and had issues running. I replaced my vacuum lines now it runs great. I wouldn't be surprised if that's your issue
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 54 Old 09-08-2013, 08:15 PM Thread Starter
Alphasolder
1987 YJ Wrangler
Supposedly the mechanic checked that
post #5 of 54 Old 09-08-2013, 08:21 PM
salsomano1a
make sure you have a strong ground to the battery to the chasis of the jeep, believe or not that was my starting problem for months.
salsomano1a is offline
post #6 of 54 Old 09-09-2013, 08:23 AM Thread Starter
Alphasolder
1987 YJ Wrangler
Do you just add a wire and hook it to the jeep?
post #7 of 54 Old 09-13-2013, 10:21 AM Thread Starter
Alphasolder
1987 YJ Wrangler
87 wrangler 4.2 won't start.
Trying to go over the vacuum it isn't right I can't find one for the lines to the carb I know they are messed up
post #8 of 54 Old 09-13-2013, 10:24 AM
jbolty
jbolty's Avatar
everything you need regarding the 4.2 is here.
http://home.sprynet.com/~dale02/list.htm
jbolty is offline
post #9 of 54 Old 09-13-2013, 06:57 PM
salsomano1a
no im talking about the normal ground that goes from the chasis to the battery.
post #10 of 54 Old 09-14-2013, 11:49 PM Thread Starter
Alphasolder
1987 YJ Wrangler
Thank you I used those diagrams worked well but my jeep won't start still
post #11 of 54 Old 09-14-2013, 11:53 PM Thread Starter
Alphasolder
1987 YJ Wrangler
Okay I will check I did just redo all the vacuum so all is fixed there but still won't run do I have a crankshaft position sensor on my jeep? I know the 4.0 have it but I looked today I see where it would hookup but I have no electric pigtail anywhere or anywhere to plug into for that matter
post #12 of 54 Old 09-15-2013, 12:02 AM Thread Starter
Alphasolder
1987 YJ Wrangler
Does all 1987 wranglers have a cps
I just got done doing all my vacuum lines. Still wont start which didn't surprise me to bad but it usually does so I checked into crankshaft position sensor and I don't have one on mine I see where it would hook up but there's no wiring harness for it and the absence of the sensor itself my motor is the 4.2 I know the 4.0 has one but does the carberatored engines have one? please help
post #13 of 54 Old 09-15-2013, 12:19 AM
Tom95YJ
Tom95YJ's Avatar
The 4.0 was not offered in the wrangler in 1987, Also the 4.0 was never a Carbureted engine it has always has had fuel injection .
Your engine should be a 258 aka 4.2L
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #14 of 54 Old 09-15-2013, 12:34 AM
Tom95YJ
Tom95YJ's Avatar
4.2 doesn't have a CPS. Your probably needing an ignition control module, Which is located on the driver side below the washer fluid reservoir
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #15 of 54 Old 09-15-2013, 07:40 AM
Old4X
1990 CJ7
For what you have already spent for no effect, you could have put an EPA approved fuel injection system on the engine.
There isn't a mechanic working today that was good with carburetors when they were still being sold on new cars. All you will find is fuel injection mechanics. If you spend the time and do the required studying, you can repair and maintain a carbed motor. But it is far easier today to just install fuel injection.
If I were still running a shop and you pulled your jeep in for repair to pass emissions, I would have to ask for $2500 cash up front with no guarantee, and all work on a time and material basis, in other words- 2500 in to see if you are serious, final price could end up far more. These are complicated setups, many parts are out of production, and most locals consider them antiques, not DD vehicles any more.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
