Help me understand gauges - JeepForum.com
post #1 of 24 Old 01-18-2010, 03:35 PM Thread Starter
r7069c
I have been studying up replacing the stock dash in my 1993 YJ. I am having a real hard time understanding how to replace the gauges. I want to know if there are any aftermarket gauges made specifically for a 1993 wrangler. Also,,, would any of the guages match up with aftermarket gauges? If so, which ones would match up and which ones would I have trouble with??
r7069c is offline
post #2 of 24 Old 01-18-2010, 03:39 PM
Fhajad
The stock setup wont work, you'd have to do some wire cutting and splicing at the very least.
The stock setup is there's a connector on the back then the connection is taken from the cable to a ribbon board and that connects via screws to the guages.
You might have to do some fabbing to make after markget guages stick, or buy a center thing to support after market guages. I know Quadratec sells one.
Fhajad is offline
post #3 of 24 Old 01-18-2010, 03:48 PM Thread Starter
r7069c
Not to be rude but I know what the stock gauges look like and how they are wired. I want to know if there are any aftermarket gauges made specifically for a 1993 wrangler. Also,,, would any of the OEM sending units match up with aftermarket gauges? If so, which ones would match up and which ones would I have trouble with?????? I'll edit my first post.
r7069c is offline
post #4 of 24 Old 01-18-2010, 05:58 PM
Mark05059
please explain what you mean by "match up"
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 24 Old 01-18-2010, 06:15 PM
Fhajad
That's what I got confused over and explained the basics.
Fhajad is offline
post #6 of 24 Old 01-18-2010, 06:31 PM Thread Starter
r7069c
Let me give you an example what I mean by match up. If you wire a fuel sending unit up to a fuel guage that came from a CJ then your fuel guage will read backwards. That's what I read on this thread . I don't want to hook up an aftermarket guage and have it read different than what it's supposed to.
I hope this clarifies.
r7069c is offline
post #7 of 24 Old 01-18-2010, 07:03 PM
idaholtby
Perhaps this will help. If you know what your gauges require, then you will know what it takes to replace them.
idaholtby is offline
post #8 of 24 Old 01-18-2010, 07:10 PM Thread Starter
r7069c
Yes. This along the lines of what I'm talking about. Now, When buying these gauges I usually don't see any specs given and I am confused on if a particular gauge will match with the specs shown here. I don't want to throw the dice and hope I get a gauge that will work. These guages get expensive. But I don't mind spending a little more if it's going to work better.
r7069c is offline
post #9 of 24 Old 01-18-2010, 07:12 PM Thread Starter
r7069c
Thank you for the specs by the way.
r7069c is offline
post #10 of 24 Old 01-18-2010, 07:24 PM
louieberner
I just replaced my gauges with VDO's, Auto meter will work also. I bought the dash bezels to mount the gauges. The gauges will come in different diameters to match the bezels. The temp and oil gauges have sending units available. I used an electronic spedometer which was easy to program. Speedo, Fuel gauge, and Tach I spliced into the PCM signal wires. Fuel Gauge was OHM specific when I bought it. GM works for Jeep.
Here's the order numbers and price paid. There are better gauges but these work fine and the whole thing cost me about $350.00
Item Qty Price
Gauge Works 15218 - 2-1/16 GAUGE BEZEL 1 US$66.18
Gauge Works 15220 - POD 1 US$64.76
VDO 437153 - VISION SPEEDOMETER 120MPH 1 US$91.32
VDO 333155 - VISION TACH 7000 RPM 1 US$65.54
VDO 332103 - VISION VOLT 12 VOLT ELEC 1 US$17.63
VDO 310105 - VISION 250 WTR TEMP ELEC 1 US$17.63
VDO 350104 - VISION 80 PSI OIL ELEC 1 US$18.52
VDO 301106 - VISION FUEL LEVEL FOR GM 1 US$16.72
louieberner is offline
post #11 of 24 Old 01-18-2010, 07:30 PM Thread Starter
r7069c
Item Qty Price
This is great information. Thanks alot POWER
r7069c is offline
post #12 of 24 Old 01-18-2010, 07:35 PM
louieberner
Forgot to mention, the bezel has one more hole, (Clock or Trans Temp)
post #13 of 24 Old 01-18-2010, 07:51 PM Thread Starter
r7069c
One more question. If I wanted to go with an anolog speedometer. Would there be any issues getting speedometer cable to hook up to my 93 yj with my AX-5? I mean since it's electric already is there still a hookup for the speedometer cable? Sorry if this sounds stupid....
r7069c is offline
post #14 of 24 Old 01-18-2010, 07:58 PM
Mark05059
Im pretty sure that there is only the provision for an electric speedometer on your particular jeep...
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #15 of 24 Old 01-18-2010, 08:01 PM Thread Starter
r7069c
THAT BLOWS!!!!!!!!!!!
r7069c is offline
Customish Electrical Gauge's Project (replace my 88 gauges with 95 gauges) kgillette YJ Wrangler Technical Forum 15 08-12-2009 08:51 AM
I don't understand bignateb Wrangler General Discussion 4 03-04-2009 08:35 AM
Help me understand this. 06flex TJ Wrangler Technical Forum 15 08-26-2007 11:02 AM
Help me understand a SYE... zband TJ Wrangler Technical Forum 4 06-07-2007 09:21 AM
Help me understand jeephreak TJ Wrangler Technical Forum 17 12-03-2004 01:41 PM
