Help me solve this popping noise(Video link) - JeepForum.com
post #1 of 8 Old 06-13-2013, 07:47 PM Thread Starter
Cashcrazy
1983 CJ7
I have a noise that sounds kinda like popcorn popping in a kettle. Listen real close and you can hear it. It's much easier to hear in person. Does anyone know what this is and what I need to do to fix it? The link below is a recording I took.
Cashcrazy is offline
post #2 of 8 Old 06-14-2013, 08:12 AM
Destr0
I hear it but can't place what it would be. Hopefully someone can help... Sounds almost like something is loose - check motor/trans mounts??
1994 Jeep YJ off road toy
1981 CJ7 SBC 350
2005 KJ Libertyt 4x4 CRD w/ 2.5" Frankenlift DD
Destr0 is offline
post #3 of 8 Old 06-14-2013, 08:17 AM
denverd1
sounds like you left a ratchet somewhere! Idk man. maybe thrust plate?
denverd1 is offline
post #4 of 8 Old 06-14-2013, 10:14 AM Thread Starter
Cashcrazy
1983 CJ7
It's hard to hear to due phone recording. Try to tune out the fan noise and head noise clattering. You can hear it the best after the engine is reved and the RPM's are dropping back down. It's more like a muffled air pop vs a ratchet banging around.
post #5 of 8 Old 06-16-2013, 07:56 PM Thread Starter
Cashcrazy
1983 CJ7
I found the source of the noise. It is coming from a hose in the air cleaner. It has a suction and the noise stops when I block the airflow. Does anyone have an idea what's causing this?
post #6 of 8 Old 06-16-2013, 08:13 PM
ROWA
ROWA's Avatar
Vacuum...
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #7 of 8 Old 06-16-2013, 08:28 PM Thread Starter
Cashcrazy
1983 CJ7
Something is working right in this vacuum hose. It is making a slurping noise. I have no idea what could cause this.
post #8 of 8 Old 06-17-2013, 08:37 AM Thread Starter
Cashcrazy
1983 CJ7
After more research I have learned that this is part of the pulse air system. About the only thing not stock on the jeep is there is no cat converter. At some point a small pipe was welded to the exhaust. I assume this was part of the the cat system at some point. Does the pulse air system actually do its job missing the converter? This particular port connects to a hose that leads to the exhaust manifold that is connected to the intake. Any ideas on this? Plug it, leave it alone or??
I have been trying to get this thing running like a new jeep with all the factory components. Now I am asking myself, What were the AMC engineers thinking with their vacuum design??
