Help me put together a YJ lift - Page 2 - JeepForum.com
post #16 of 28 Old 09-06-2011, 11:50 AM
misterpookie
the name of this thread disturbed me.
misterpookie is offline
post #17 of 28 Old 09-06-2011, 11:59 AM
SFJeep89
Easiest way for me cause at the time I didn't know much about lifting anything was to buy the RC 3in lift kit and a 2in bl to go with it. I fit 33's really nice and was under 500 bucks. I still have the bl but the lift lasted 4 years before I decided to go soa. My jeep use to be a reliable weekend warrior.
SFJeep89 is offline
post #18 of 28 Old 09-06-2011, 01:20 PM Thread Starter
seraph_rapture
Here's what I've come up with so far
4 - 004351 BDS springs from BDS = $475.69 shipped to distributor
2 H7059 shocks for front 2 H7088 for rear = $109 shipped from Skyjacker
1 - Dropped Pitman arm = $60.26 shipped Amazon prime
U bolts and hardware I think I can pick up local unless you know of somewhere to get it online. What about bumpstops? Anything else I'm missing?
seraph_rapture is offline
post #19 of 28 Old 09-06-2011, 01:30 PM
Sawicki4wd
Transfer case drop or sye. I'd suggest a sye. The tc drop doesn't help to much. But it does enough. And its prolly 400 cheap then a sye
Sawicki4wd is offline
post #20 of 28 Old 09-06-2011, 01:34 PM
HurricaneRZA
bushings? Or do they come with the springs?
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #21 of 28 Old 09-06-2011, 01:35 PM Thread Starter
seraph_rapture
SYE is in the mail from Jeeperz Creeperz
post #22 of 28 Old 09-06-2011, 01:38 PM Thread Starter
seraph_rapture
Good question - BDS' website doesn't specify. Anyone?
post #23 of 28 Old 09-06-2011, 01:41 PM
TheNewbie
You may or may not need bump stops with that 2" BL. Without that BL I'd say yes for sure. But with a 2" BL you might get away without them. It will be close. I'd put the lift on and then SLOWLY flex it out to see how far you can stuff the tires.
I have 33's with flat fenders up front and TJ flares in the rear and no longer need the bump stop extensions. The stock bump stops are enough. I'm guessing that you might slightly rub at full flex, but it's hard to tell how much extension of the bump stops you'll need. It might only be like an inch.
If you want to order up some bump stops to be safe then go fo it. But going with a longer bump stop than needed will only serve to limit flex. That's the only reason I say to measure after you get the lift and get them later.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #24 of 28 Old 09-06-2011, 01:48 PM
giggityjeeper
My old men emu springs were cheaper then that shipped to me, and a better spring, I would check those as well....
EDIT... oops no they were not, lol. about hte same tho just checked again.... was $486
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #25 of 28 Old 09-06-2011, 01:58 PM Thread Starter
seraph_rapture
OME are 2.5, these are 3.5
post #26 of 28 Old 09-06-2011, 02:04 PM
giggityjeeper
try this one more time, the 36R I suggested are a 5 pack leaf, I ran the 14F for a lont time in the front...I nose dived, the 14 are a 4 pack, The 36R ar a good 3" if not more, they dont advertise this way, but with those and your shackles same as me, 5/8 greasables, you will get over 3" for sure and have a far superior spring....
the difference being this.... your RC, BDS, RE, will sag most definately, well maybe not BDS, but the others for sure, my OME I run all gear, kids, spare, and still sit level.... ran them SUA for years and now SOA and still hold up well...
post #27 of 28 Old 09-06-2011, 02:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Bushings are an extra $20. I would also opt for some greasable shackle bolts to make best use of the new set up.
Luck Favours The Prepared
Anticanman is offline
post #28 of 28 Old 09-06-2011, 02:43 PM
Sawicki4wd
My re don't sag at all unless I have my extremely over weight friend (355 lbs) in the back with 2 other people. I couldn't be happier with my lift it's been on for 2 years since I bought the jeep and 3 years before that and they still have the same amount of lift. And they flex amazing. I would buy these again in the blink of an eye.
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 09:11 AM
BL Body Lift install / Fan clutch / Motor Mount Lift sorta ... Mike_Motorbike TJ Wrangler Technical Forum 3 02-21-2011 12:33 PM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 06:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 08:13 PM
