Help me put together a YJ lift - JeepForum.com
post #1 of 28 Old 09-06-2011, 07:42 AM Thread Starter
seraph_rapture
Originally I had planned to just buy a RC 4" SUA kit due to the ease of having everything in one place and the price of around $450. The more I read though, people seem to advice piecing one together yourself. As I don't have the experience with lifting a YJ I'm soliciting your help to ensure I get this done the right way.
Obviously buying the RC kit would be the easiest way to do things, but I've heard that the lift tends to sag quickly. I have also heard that they have switched vendors for their springs - does anyone know if this has eliminated the problem?
Outside of that what would you recommend for individual pieces for a lift and where would you recommend purchasing it? My criteria are that I would like something I know isn't going to sag immediately and would like to keep it around $500 or less. I know I'll need the following, let me know if there's anything I'm missing.
front and rear leaf springs
power steering pitman arm
sway-bar links
front and rear track bar brackets
brakeline relocation brackets
bumpstops
u-bolts and hardware
four shocks.
seraph_rapture is offline
post #2 of 28 Old 09-06-2011, 07:46 AM
YelloJeep
For what it's worth, my YJ had a Rough Country lift on it when I got it 2 years ago and I haven't had any trouble out of it.... Also, I am planning on removing my track bars to get more flex..... (Might not want to invest in the brackets for those...). Also I am no expert!
YelloJeep is offline
post #3 of 28 Old 09-06-2011, 08:16 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
The first question should be: How high do you want to go and what tire size are you wanting to clear? If you are going with 31" tires then a 2" - 2 1/2" lift is good. If you are going with 33" tires then a 3 1/2" to 4" lift is what you are wanting.
Here is your list:
power steering pitman arm (drop pitman arm is only needed on 4+" of lift)
sway-bar links (get sway-bar disconnects)
front and rear track bar brackets (throw them away, or keep in a box in the garage for inspections. YOU WILL NOT NOTICE THEY ARE MISSING!!! but will have better ride and better flex)
brakeline relocation brackets (you will need these if you remove your track bars and disconnect your sway bars. If you keep your sway bars then you won't need them because you won't flex enough to worry about it.)
bumpstops
four shocks.
Things you may add:
Spring eye bushings and shackle bushings
Transfer case drop kit (or if you have the $$ a SYE and new rear drive shaft)
I finally removed my front track bar (never put the rear one back on during my rebuild) and disconnected my sway bars, here is the difference in flex:
I took it wheeling last weekend and places I used to have trouble on I tackled without even slipping a tire. I wish I would have done it sooner!
As to a brand of springs? Everyone will suggest OME or BDS. I don't have experience with either one. I have an inexpensive 1.5" Supperlift with 5/8" lift MORE boom shackles and it clears my 31" tires and flexes great. Rides great and hasn't sagged in two years. I got the complete kit (minus the shackles) for $400.
HTH
-John-
johnboy68 is offline
post #4 of 28 Old 09-06-2011, 08:38 AM
Sawicki4wd
Rubicon express makes a really nice set of leafs and so does bds. I'd stray away from rc they seem to be hit or miss with them. And I know for a fact that they don't flex nearly as good as say rubicon express leafs. I have rubicon express 4.5 leafs and with no sway bar or track bar. I have never lifted a tire. Get a good set of shocks. If you do a 4" lift get 5" lift shocks. On my lift I have 6" shocks. They allow you to keep you tires on the ground. But your I. The right track with piecing it together. And if your on a small Budget check craigslist
Sawicki4wd is offline
post #5 of 28 Old 09-06-2011, 09:02 AM Thread Starter
seraph_rapture
Thanks for the help guys, since the question was raised I'll give you the info I have.
I'd like to fit 33's on. I considered 35's, but don't want my jeep sitting 12 feet in the air.
I'm looking at 4" of suspension lift or thereabouts. I have 2" of body lift now and ordered 5/8 boomerang shackles.
I just put in an order for an SYE and have an XJ ds that I plan to use.
People are suggesting BDS to me but I can't see spending 1500 on a lift kit. Perhaps if I just used the springs and sourced the other things somewhere else it wouldn't be so bad.
post #6 of 28 Old 09-06-2011, 09:11 AM
giggityjeeper
4 36R Old Man Emu springs, your shackles, some new shocks, the SYE you have, the shaft you got, and your golden for 33s......and you wont find a better springs anywhere...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #7 of 28 Old 09-06-2011, 09:41 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Go to this thread:
http://www.jeepforum.com/forum/f12/m...79/index2.html
and read post #25
-John-
post #8 of 28 Old 09-06-2011, 09:50 AM
Sawicki4wd
If you piece a lift together chances are ul get a better lift and save a few hundred bucks in the process. If you only want 33s get a 2.5 or 3 in lift seeing how you have a 2" bl. I have 4.5 re leafs and 1" boomerang shackles. And my 35s rub with 4 people in my jeep just on the street. In going to tj flares so it's no big deal. Just something to think about. You can fit 33s stock with the right flares and trimming. But is stick with a lift. But it can be done there was a write up in Jp mag of a stock tj with 35s with plenty of flex room left b
post #9 of 28 Old 09-06-2011, 10:48 AM
notmyj
pay attention to what most of us have said in other threads. We are not recommending a BDS kit. We are recommending BDS springs. The springs will make or break your lift. You really do get what you want. A co worker of mine is doing an SOA on BDS 2" springs. The springs cost him under $100/ea.
Piece together a kit and either go with BDS or OME springs. Do this and you too will be a believer of good springs.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #10 of 28 Old 09-06-2011, 11:02 AM
TheNewbie
Your list looks good but you don't need the sway-bar links, front and rear track bar brackets or brakeline relocation brackets. Just remove the sway and trac bars and unbolt the brake lines at the frame and pull them down a bit. That shuold be good until you get over about 5" of (suspension)lift. Your 2" BL will not effect the brake lines at all. I run a 4" lift and still ahve slack in my brake lines when the axle at full droop. And all I did was unbolt the lines and bund them down over the frame a bit.
Personally I would get some OME springs. I went with RC, and they sag really quickly and ride like crap. I got them for the price, but I'm tired of dealing with them now and will be switching to OME's. And yes... I have the " new RC springs". They still sag and ride like crap. Either go with the 36R OME springs or go BDS. You won't regret either.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #11 of 28 Old 09-06-2011, 11:04 AM
notmyj
Originally Posted by TheNewbie View Post
Your list looks good but you don't need the sway-bar links, front and rear track bar brackets or brakeline relocation brackets. Just remove the sway and trac bars and unbolt the brake lines at the frame and pull them down a bit. That shuold be good until you get over about 5" of lift.
You might also want to add a transfer case drop tot hat list. Depending on how much you lift it you might even get away with using some washers as spacers.
No worry on the t-case drop, a couple posts up he said he ordered an SYE.
notmyj is offline
post #12 of 28 Old 09-06-2011, 11:12 AM Thread Starter
seraph_rapture
Thanks again. Is there a place I can order 3.5 or 4" BDS springs, bushings, and as much as what I'll need to do SUA in the same place to cut down on shipping costs?
post #13 of 28 Old 09-06-2011, 11:15 AM
Kamikaze
Have you givin' "Fat Bob Garage" in Ogden Utah a look at? They make very good suspension produce and are very helpful. Also their price is reasonable. Some of these local shops do make amazing product for less money then a big namebrand. My opinion. Good luck.
Live Free, Laugh Loud and be Friendly.
Kamikaze is offline
post #14 of 28 Old 09-06-2011, 11:32 AM
notmyj
From www.BDS-suspension.com
The part number for the springs will be 004351 This is the heavy duty spring for the front and rear. It will support the weight of the spare tires, bumpers, winch, etc.
Call BDS and talk to them. They prefer you order from your local distributor but they will sell direct to you. You can order from their website if you want, but you can get free shipping if you have it shipped to your local dealer.
I would order the springs from them, then everything else from where ever you can find the best deal. 4wd.com, Q-tech, 4wheel parts, etc.
notmyj is offline
post #15 of 28 Old 09-06-2011, 11:49 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Don't waste the money on tax and possibly shipping by ordering from your local dealer. Find your lift springs in the BDS catalog and order through the website and have it shipped to your local dealer. My dealer was a jerk and tried to charge tax (legally he has to) and shipping (because the order wasnt over $1000). Shocks can be had for $30 apiece and the shims will have to be measured for and ordered while your driveline is being built. If you have any specific questions, refer to some of my other posts on the subject or feel free to PM me. You wouldn't be the first asking for a build plan. Dont forget to factor lift shackles into your lift plans! Full mil wrap springs will not work with stock shackles.
Everyone pretty much covered everything up there, I just posted cause I'm bored.
Luck Favours The Prepared
Anticanman is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
Body Lift vs. Suspension Lift...Difference? Pics? Rough Country myoung YJ Wrangler Technical Forum 14 07-24-2011 09:11 AM
BL Body Lift install / Fan clutch / Motor Mount Lift sorta ... Mike_Motorbike TJ Wrangler Technical Forum 3 02-21-2011 12:33 PM
Confused. Why 4" suspension lift plus body lift instead of taller suspension lift? ezgoin TJ Wrangler Technical Forum 34 02-12-2011 06:04 PM
Can I do this? Adding more lift to RC Series II 4" lift. Body lift or coil spacers? gattaca37 TJ Wrangler Technical Forum 20 09-12-2010 08:13 PM
