Help me with my Brakes... - JeepForum.com
post #1 of 15 Old 08-31-2014, 05:13 PM Thread Starter
BRC_1980
I know I may be dumb but I've done brakes many times and this time I'm stumped. Mind you, never on a jeep. Below you can see.
The top part of the caliper is 1/4" short from getting on. It just won't go over. When my old pads are on, it fits with ease but those are old. There's no way to push the middle part any further back.
BRC_1980 is offline
post #2 of 15 Old 08-31-2014, 06:45 PM
kmagnuss
It doesn't fit because everything on your jeep is too clean. It has no business looking like that. Rub some dirt on it and make it leak oil somewhere and it will fit... promise.
It's Herbie Hancock... Derrr.
kmagnuss is offline
post #3 of 15 Old 08-31-2014, 06:50 PM
Mike Romain
Take the red plug out and try. ;-)
Mike
Mike Romain is offline
post #4 of 15 Old 08-31-2014, 07:01 PM Thread Starter
BRC_1980
It's clean because there isn't a thing on it that has been used. It can't be used because I can't figure out the stupid brake thing. I had a mechanic of 30 years stumped. He tried for 1 hour and said he has to go lol. Oh, and it does leak, that's the next project. I'm sure that will go as well as this.
Red plug is added color to this all black thing.
BRC_1980 is offline
post #5 of 15 Old 08-31-2014, 07:09 PM
Mark05059
you may have the wrong rotors and possibly pads.
see if this helps http://www.jeepforum.com/forum/f12/f...itment-893491/
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 15 Old 08-31-2014, 07:20 PM Thread Starter
BRC_1980
Rotors are identical. Calipers are the exact same. I replaced them just because I thought I couldn't push the calipers back far enough to fit as in picture 2 but I actually did. The only thing different are the size of the pads. The only reason there is a difference of size is because one is old and the other new. That thread is for 90 to 95 (oh nm re-read it) and it is the same as the videos I've watched which haven't helped. Still doesn't make since why it's this much trouble.
The pads are right. I checked online and called Napa, Autozone, Pep Boys, and Whoopies or whatever. All told me the same. I wish one would say different because I would try those.
BRC_1980 is offline
post #7 of 15 Old 08-31-2014, 08:01 PM
Steve707
Are those retaining clips necessary? I don't ever remember having those with stock brakes. I doubt that would cause a quarter inch difference in the calipers going on or not though. Are the calipers the same as the old ones? The rotors? Something has to have a wrong part number. What year jeep do you have, and can you post pictures of the old stuff?
Do the old calipers go on with the new pads and old rotors?
Steve707 is offline
post #8 of 15 Old 08-31-2014, 08:09 PM
Mark05059
was looking at your picture with the rotors.. there isnt much stud sticking out to put the wheel on? Check the height to the inside of the hat.. it makes a big difference there... not the height to the outside. take pictures of your old parts next to your new parts...something has to be different... did you take both sides apart at the same time or one at a time? If the other side is still together take pictures of that side..
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #9 of 15 Old 08-31-2014, 08:35 PM
mike134
How is this jeep so shiney and new?!
mike134 is offline
post #10 of 15 Old 09-01-2014, 05:56 AM
Jones-Maryland
Please fill out your profile, what year jeep. The brake mounts changed sometime in 89-91 so important to get the right parts. I know I went down this road with mine, also I have been given parts that were incorrect but the store swore they were, went to a different company to get the right one. Just a thought.
Jones-Maryland is offline
post #11 of 15 Old 09-01-2014, 06:21 AM
Old4X
1990 CJ7
Wrong parts. Parts house counter guys are not mechanics. Get parts that fit what you have and it will work.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #12 of 15 Old 09-01-2014, 08:10 AM
jbolty
jbolty's Avatar
looks like wrong rotors to me and I've never seen those clips on a YJ before, though I suppose it might have been factory OEM
jbolty is offline
post #13 of 15 Old 09-01-2014, 09:39 AM Thread Starter
BRC_1980
They gave me the wrong pads. They wouldn't go back far enough but switched them and it worked. The last guy I called. Thanks guys.
It shiney and new because everything has been replaced.
BRC_1980 is offline
post #14 of 15 Old 09-01-2014, 05:29 PM
IA93Javert
Huge help though from everyone. I have my new rotors, calipers and pads on the way. If I have a problem I will be sure to spill some dirty oil on them and roll them in the dirt before the pics..
IA93Javert is offline
post #15 of 15 Old 09-01-2014, 09:30 PM
mike134
I second this notion a million million times. I do not like those parts jerks...
When I lived out in the country, the autozone people knew what they were doing. Here in the city, I don't know how any of the service employees can even function in society...
mike134 is offline
