Help me identify these wires - JeepForum.com
post #1 of 16 Old 07-28-2013, 11:25 AM Thread Starter
Jeeperez
I have 3 wires coming out of the back of the tub of my 1993 YJ
1 Green (Ground)
1 Black (Power when lights are on)
1 Yellow (Does nothing)
I know my YJ came with a tow package from the factory, is this the wiring for it? It wouldn't make sense because it wouldn't control blinkers ect
I was going to splice into it for my 3rd brakelight because I was assuming the yellow was brake power but I'm not getting any power out of it from anything
Anyone?
Matt
Originally Posted by daverubino View Post
Sell your YJ???? Why would anyone do that. You dont sell YJ's you just keep them until they become parts heeps for your next one.
Jeeperez is offline
post #2 of 16 Old 07-28-2013, 11:43 AM Thread Starter
Jeeperez
Also with the stock hardtop wiring (on the harness end) I'm confused on what is what.
I have constant power on the pink wire but only have power on the yellow wire when the door is closed. The other wires do nothing
Shouldn't it be opposite? Power into yellow when the door is open? How is the courtesy light supposed to light up. My YJ came factory with a hardtop with wiper
I now have a hardtop that has defrost. I don't have the original hardtop
Matt
Jeeperez is offline
post #3 of 16 Old 07-28-2013, 02:31 PM Thread Starter
Jeeperez
Anyone?
I'd like to tap into a wire somewhere to allow the 3rd brake light to work. I don't understand the 3 wire wiring system of the brake lights
And to tap into the brake light switch I don't know what wire is outgoing??
Matt
Jeeperez is offline
post #4 of 16 Old 07-28-2013, 07:09 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
1 Green (Ground)
Anyone?
Hit the brakes and see if the yellow light ends up with voltage. It may be the brake light. Keep in mind the tail light bulbs have 2 filaments one for tail light and one for brakes/turn signals.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 16 Old 07-28-2013, 07:15 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I had some input for a '95 HT wiring question. The wire colors are probably not the same for your '93 but the pathways are the same and so are the locations/pin outs.
http://www.jeepforum.com/forum/f12/h...arness-866334/
post #6 of 16 Old 07-28-2013, 08:38 PM Thread Starter
Jeeperez
I had my wife step on the brakes; key on or key off, lights on or lights off there is no power going to the yellow wire. I have no idea what its for
I ended up splicing into the driver side tail light for now just so I could get the 3rd brakelight to work
As for the hardtop I got as far as figuring this..
Black (Ground)
Yellow (Switched Power via courtesy lights..door closed gives power)
Pink (Constant Power)
Brown w/white stripe (Switched power via wiper/washer switch)
Brown w/yellow stripe (Unknown)
Brown w/black stripe (Unknown)
If the yellow wasn't switched backwards I would just be able to use it as the courtesy light (dome on HT) and then use the wiper/washer switch for the defroster
Matt
Jeeperez is offline
post #7 of 16 Old 07-30-2013, 06:21 AM
Myjeep1986
Rear wiring
Check out justjeeps.com service manual, group 8W pages 108 through 111 out of 240; this is the book I have and used to do entire rewire from fog lamps to license plate light;
Also the 3rd brake light is fed from 2 wires exiting the tailgate from right rear wheel well;
Myjeep1986 is offline
post #8 of 16 Old 07-30-2013, 09:03 AM
XJ93
The yellow isn't exactly switched backward. With the door closed it provides ground, giving power to that circuit. May want to check the wires on your jamb switch and see if they are reversed.
XJ93 is offline
post #9 of 16 Old 08-01-2013, 05:50 PM Thread Starter
Jeeperez
By jamb switch do you mean the switch on the door sill?
Heres an update because I believe the wire colors I said before were wrong
On the HARDTOP
BLACK w WHITE STRIPE - Ground for Dome
PINK- Power for Dome
BLACK- Ground for Defroster
BROWN w WHITE STRIPE- Power for Defroster
On the TUB
PINK- Constant
YELLOW- Power, switched via door switch
BROWN w GREEN STRIPE- unknown
BROWN w GRAY STRIPE- Switched via washer switch
BROWN w YELLOW STRIPE- unknown
BLACK- Ground
Door Switch
Yellow
Black w green stripe
I tried putting the hardtop ground to tub ground and then HT pink to the tub Yellow but I get very little voltage going to the bulb, its very dim. It gives power when the door is closed and shuts off when the door is open but it also stops the switch on the door from shutting off the foot lamp at all, just goes dim to bright and vice versa. It returns to normal when I undo the wiring from the HT. The bulb works bright as day when attached to the pink constant power from the tub.
What am I doing wrong, I am just trying to get the dome light to switch with the foot lamp so I have interior lights working properly
Matt
Jeeperez is offline
post #10 of 16 Old 08-01-2013, 07:39 PM Thread Starter
Jeeperez
bump for some help
Matt
Jeeperez is offline
post #11 of 16 Old 08-01-2013, 08:04 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Keep in mind that the wire colors are different for different years...UNLESS they didn't change the wire colors......
post #12 of 16 Old 08-01-2013, 08:21 PM Thread Starter
Jeeperez
Thank you for the diagram, it helps.
So according to that, I should not be using the ground on the harness but should be connecting the circuit from constant power (pink) to lamp to yellow (which I am also getting a very low voltage). The colors match exactly what I have.
Or is the voltage i'm getting on the yellow backfed giving me the low voltage because its grounding out
Matt
Jeeperez is offline
post #13 of 16 Old 08-01-2013, 08:37 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I think you got it right. The switches/lamps self ground by being in contact with the body circuit M1 the pink wire is the power source. The M2 circuit is the other half of that connecting circuit so to speak. The rear dome lamp also gets it power through the M1 circuit on another pink wire in the tub harness and the M2 circuit is also present in the tub harness to accomplish the same thing again.
post #14 of 16 Old 08-01-2013, 08:45 PM Thread Starter
Jeeperez
Ah it makes sense now. As for the passenger side door jamb and lamp was that an option from the factory? I believe the wiring is there but I only have a rubber plug where the door jamb should be and no light
Matt
Jeeperez is offline
post #15 of 16 Old 08-02-2013, 06:36 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Good question. I have no idea if those cheap buggers made the pass side light switch an 'option'. That switch is pretty much standard on any other car I have seen going back to the 40's
