Help me ID these plugs - JeepForum.com
post #1 of 10 Old 06-22-2009, 06:31 PM Thread Starter
czjeeper
While looking for my rear defrost switch plug, I came across these two unknow plugs.
anybody know what they are? What's my rear defrost plug look like?
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 10 Old 06-22-2009, 07:14 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
In the first pic those plugs are for the courtesy light switch in the door jamb. Not sure about the plug in the second picture.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 10 Old 06-22-2009, 07:21 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I think the plug in the second picture is for you fog lamp switch.
post #4 of 10 Old 06-22-2009, 07:25 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I know for the '95YJ the rear defroster switch in the dash is RED Then in the tub harness near the parking brake near the door jamb is a RED relay socket and a RED relay marked TIMER on it. It has been discussed many times before. Just do a search through the thread history
post #5 of 10 Old 06-22-2009, 09:18 PM
UnFocused
Laybackman is right on both counts. The light green colored wires is the key for the second plug, it's your fog lights.
UnFocused is offline
post #6 of 10 Old 06-22-2009, 09:26 PM Thread Starter
czjeeper
Strange, I don't even have fog lights.
I have the relay and correct harness for the rear defrost, I was hoping to find the plug for the switch. I guess I'll have to dig around some more.
Thanks for the help!
US Army combat vet
czjeeper is offline
post #7 of 10 Old 06-23-2009, 08:19 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
I am pretty sure that the dash harness has a red socket for the rear defroster switch. Mine did BUT my tub harness did not have the relay or wiring associated with the RWD. I bought another harness off of EBAY, stripped out that wiring and married it into my harness.
Your tub harness must have this timer relay and relay socket on it. Their location is by the parking brake against the tub. Power to the switch only powers the relay not the RWD.
post #8 of 10 Old 06-23-2009, 10:46 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
You YJ may not have come with fog lights BUT the dash harness most likely had the wiring for it since they are tied to the low beam relay. When you turn the high beams on the fogs go off. If you add the fog light switch and slap on some fog lights you would be good to go as far as fogs are concerned. Check the harness near the head lights to see if it has the factory wiring for the fog lamps. They may be down near the front bumper.
post #9 of 10 Old 06-23-2009, 11:36 AM Thread Starter
czjeeper
I've added the tub harness with the red relay (ebay).
My rear wiper now works.
I guess I'll need to hard wire the relay for the rear defrost.
US Army combat vet
czjeeper is offline
post #10 of 10 Old 06-23-2009, 12:34 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Here is a link to what the circuit looks like. RIGHT CLICK then save target as:
http://home.comcast.net/~laybackman/95yj_rwdcircuit.pdf
I'll leave it up for a while.
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 09:37 PM
E3 plugs? antec YJ Wrangler Technical Forum 4 07-12-2009 09:20 AM
Plugs gargyle TJ Wrangler Technical Forum 1 07-11-2009 10:58 AM
Can someone ID these plugs please Reverb YJ Wrangler Technical Forum 9 04-06-2009 09:33 AM
Splitfire Plugs vs. Standard Plugs Alphadux TJ Wrangler Technical Forum 8 11-19-2003 07:35 PM
