Help me help a friend please. - JeepForum.com
post #1 of 9 Old 09-19-2013, 06:10 PM Thread Starter
spottedfrog
1979 CJ5
So I'm trying to help a friend long distance.
He has a '89 YJ SE 2.5L, 5 speed, owned since new and bone stock.
He said that It will randomly only get up to 20 mph. while driving and sometimes refuse to turn over.
He said that the vehicle was getting driven regularly until it developed problems.
I'm unfamiliar with the 2.5L and had thought that it was still using a carb, but apparently they are TBI.
It has new plugs/wires, starter.
I was thinking it could be possibly a problem with the vacuum advance, or with the ignition control module.
Maybe an O2 sensor?
did the 2.5L have a crank angle sensor?
What else would you suggest.
Thanks
spottedfrog is offline
post #2 of 9 Old 09-19-2013, 06:41 PM
scraper
Does he have manual or Auto?
But honestly this could be a whole lot of things. Has he checked the error codes. I would start there. Let us know if we can pin point the problem area that way.
scraper is offline
post #3 of 9 Old 09-19-2013, 06:42 PM
scraper
NM on the manual or auto I just saw the 5 speed part in your post.
scraper is offline
post #4 of 9 Old 09-19-2013, 06:46 PM Thread Starter
spottedfrog
1979 CJ5
I don't think he has access to a code reader.
could also be a clogged fuel filter.
normally on a vehicle this old I'd suspect the filter, and vac lines???
post #5 of 9 Old 09-19-2013, 07:07 PM
mudsweatNgearz
1987 YJ Wrangler
there is no vac advance on FI
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #6 of 9 Old 09-19-2013, 07:16 PM
scraper
Not 100% sure about an 89 but I don't think he needs any tools to check the fault codes. Follow this link
http://www.jeepforum.com/forum/f12/h...codes-1257145/
scraper is offline
post #7 of 9 Old 09-19-2013, 07:28 PM
bigbossd1030
Yup, key trick should wok just fine.
Also, could be clogged cat?
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #8 of 9 Old 09-19-2013, 07:44 PM Thread Starter
spottedfrog
1979 CJ5
Thanks every one.
I know it can be any one of a lot tof things, that's what I'm having a hard time with especially long distance. I was hoping to narrow it down to issues that seem to come up with this model.
post #9 of 9 Old 09-20-2013, 08:47 AM
Que89YJ
No code reading for the 89. It was pre OBD I. You need to narrow it down. When it isn't starting you said it doesnt turn over. Do you mean the starter doesn't work?
Que89YJ is online now
