HELP! manual transmission reverse problem - JeepForum.com
post #1 of 4 Old 10-01-2004, 07:18 PM Thread Starter
jeep75
I have a 91 yj with a 4 cyl 5 speed with 79k miles on it. the transmission and transfer case was rebuilt 500 miles ago by a reputable 4x4 shop. Tonight when i was going into reverse it started grinding when trying to go in. You could feel the gears turning on the stick. if you would let the clutch out and back in sometimes it would go right in other times same thing. i've noticed that at a stop it's kinda hard once in a while to go into 1st you really have to give it a push. but nothing w/ reverse until tonight. any ideas and if so, how much money are we talking - i've already drained my life savings it seems like
1991 yj Red Wrangler 2.5 liter 5 speed - herculined
1997 zj Black Jeep Grand Cherokee Limited I-6 select trac
empty wallet ;-)
jeep75 is offline
post #2 of 4 Old 10-01-2004, 07:39 PM
ZR7 Ken
ZR7 Ken's Avatar
It sounds as though you have a clutch release problem more than a transmission issue.
If you shut off the engine, is it easier to shift? If it is, check your clutch master cylinder fluid level. If that's OK, you may have a pressure plate that's binding.
ZR7 Ken is offline
post #3 of 4 Old 10-01-2004, 09:09 PM Thread Starter
jeep75
yes if i shut off the engine it goes in just fine. is that something that requires the transmission to be torn apart? either way what does something like that cost to get fixed. I've spend some much already and the transmission was rebuilt last summer (by previous owner)
empty wallet ;-)
jeep75 is offline
post #4 of 4 Old 10-08-2004, 08:45 PM
beddo
Sounds like your hydraulic throw out bearing could be bad or have air in the line. I would bleed the clutch system first before tearing anything apart.
beddo is offline
Automatic transmission Reverse gear problem. ksl TJ Wrangler Technical Forum 32 03-11-2010 07:21 AM
6 spd manual transmission problem/death cyberiv TJ Wrangler Technical Forum 5 09-08-2009 01:58 PM
manual, hard to get in reverse nashvillwill TJ Wrangler Technical Forum 15 12-30-2008 11:18 PM
Just installed a reverse 1" body lift. Problem staying in reverse. Talos YJ Wrangler Technical Forum 4 10-07-2006 10:05 PM
Synchro'd 2005 manual reverse grinding Driller TJ Wrangler Technical Forum 15 02-14-2005 03:59 PM
