Help...maintenance required light - JeepForum.com
post #1 of 8 Old 01-04-2005, 09:44 AM Thread Starter
a204600
What needs to be changed or fixed to make the maintenance required light go out. I have changed the O2 sensor already. The jeep is a 92 with the inline 6. any info will help.
a204600 is offline
post #2 of 8 Old 01-04-2005, 10:03 AM
traildust
Have you run your codes. Do you know how? If not do the following turn your key on, off, on, off, on the dash light should blink. Something like this two blink a pause three blinks pause that would be 23. This is just an example. You will most likely get one or more codes.
traildust is offline
post #3 of 8 Old 01-04-2005, 12:08 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
hey's talking about the maintenance light, not the check engine light.
A20, i believe the 92's used the electronic timers and can be reset at the dealer (or possible other shops). if not and they used the mechanical style timer, the timer itself needs to be replaced or disconnected. it's located under the dash, just above the accelerator and to the right a bit. HTH
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #4 of 8 Old 01-04-2005, 12:20 PM
traildust
Thanks I didn't know there was one. New at all this stuff.
post #5 of 8 Old 01-04-2005, 12:34 PM Thread Starter
a204600
got code, what do they mean
Ok I got the codes, now can someone let me know what they mean:
12
33
15
55
a204600 is offline
post #6 of 8 Old 01-04-2005, 01:03 PM
Atwater10
Atwater10's Avatar
Hello a204600, I don't know if the codes are the same on your '92, but here is
something that I found for a '95:
These codes were taken from the '95 XJ/YJ
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
33* An open or shorted condition detected in the A/C clutch relay circuit.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
I hope this helps.
Chuck
'94 YJ 2.5L/5sp - White Jeep Club #55
Atwater10 is offline
post #7 of 8 Old 01-04-2005, 02:11 PM
Questor
Questor's Avatar
You'll have to have the Maint Req'd light reset at the dealer...Or just pull the bulb as many have mentioned. If you're confident in the new O2 sensor and you remember to replace it in 40k-80k then you'll be fine.
I wouldn't worry about any of those codes except the #15 one - did you disconnect your speedo sensor? Does your speedo work properly?
'92 YJ Sahara / OME / BFG AT/TA - a few other rides.
Questor is offline
post #8 of 8 Old 01-04-2005, 03:25 PM
RCHavok797
RCHavok797's Avatar
Take a look at the frequently asked question thread at the top of the YJ forum, it is there for a reason and contains a lot of information.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
maintenance required light onlyjeep YJ Wrangler Technical Forum 18 09-19-2009 08:46 PM
maintenance required light JeepMKcomin YJ Wrangler Technical Forum 12 03-20-2008 09:15 AM
maintenance required light please help slmcook YJ Wrangler Technical Forum 10 02-26-2005 07:37 PM
Maintenance required light came on? DevilDogJeep YJ Wrangler Technical Forum 9 01-07-2005 12:34 AM
Maintenance required light..Whats up with that?? sturgman YJ Wrangler Technical Forum 5 12-16-2003 08:43 AM
