Help with lighting when takin doors off - JeepForum.com
post #1 of 2 Old 07-19-2004, 11:15 AM Thread Starter
Grant
Question: I just got a 95 Wrangler. How do I disable the interior lights under the dash when I remove the doors? The right side does not have a quick disconnect, and I removed (unplugged) the black and yellow wires on the drivers side but the lights are still on (the dimmer switch is NOT on). Any help appreciated.
Thanks in advance.
Grant is offline
post #2 of 2 Old 07-19-2004, 10:27 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Both sides have a disconnect plug on the backside of the switch.
For the passenger side, the single wire just pulls free of the switch .. driver's side you need to pull both connections.
An alternative is to use duct-tape to open the connection inside the switch.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
A couple lighting questions (mounting locations and reverse lighting) Rush1184 YJ Wrangler Technical Forum 7 02-14-2008 09:48 AM
takin out the tranny jeep795 YJ Wrangler Technical Forum 12 06-09-2007 08:39 AM
Takin it to the shop Ares YJ Wrangler Technical Forum 8 09-01-2006 11:37 AM
Takin the Doors off TJSaraha03 TJ Wrangler Technical Forum 20 05-24-2006 09:49 PM
takin carpet out??? boozer1022 TJ Wrangler Technical Forum 13 07-13-2004 11:47 AM
