help with lifts and axles - JeepForum.com
post #1 of 11 Old 04-13-2001, 04:28 PM Thread Starter
SaHaRa JeePeR
ok, i'm interested in doing a spring over for my jeep. where is a good place to get a kit i know rub -ex has one and a couple other companies. I'm also wanting to do an axle swap for some dana 44' or ford 8.8". where should i start, i know i'm going to need a sye and a few other parts but i just wanna know if i'm headed in the right direction,
94 sahara (i got 6 mice that can't stand there 3.07 wheel they run on)
SaHaRa JeePeR is offline
post #2 of 11 Old 04-14-2001, 04:17 PM
osburn
osburn's Avatar
Rubicon Express is the only company I know of offering a production SOA kit. I know a lot of shops will do the SOA, but it's considered purely custom work. And it's expensive. If you do know of other companies offering SOA kits, please post about them here. I'd sure like to look over the information for future reference.
If you don't plan to do the research for a custom SOA, then I'd say going with the RE kit is probably your best bet. I haven't seen the kit myself but have seen a lot of reports from fellows that say the kit is complete and the instructions are fairly good. And I'm sure you're aware, this is a weld in kit and not a bolt on kit.
Matt Osburn
Score 1032
osburn is offline
post #3 of 11 Old 04-14-2001, 04:22 PM
Tonka
2015 JK Wrangler
Keep in mind that you'll probably have some axle wrap issues.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #4 of 11 Old 04-14-2001, 06:12 PM Thread Starter
SaHaRa JeePeR
umm i think superlift used to make a springover kit. yes i do know it is weld on and i do own a welder as far as axle wrap
i think i'm goning to use add a leafs to help with that some.how much is a trac bar?
post #5 of 11 Old 04-14-2001, 09:09 PM
Tonka
2015 JK Wrangler
By axle wrap, I meant that when under hard acceleration the springs tend to twist, sort of into an "s" shape Which in turn causes your tires to "hop" and temporariily loose traction.
98 TJ
90 XJ 2 dr 4x4
Tonka is offline
post #6 of 11 Old 04-15-2001, 03:34 PM
osburn
osburn's Avatar
Not a "trac" bar, but a "traction" bar. Believe it or not, they're different. Your YJ comes equipped with a "trac" bar front and rear. It's used to keep the axle lined up laterally underneath your Jeep. It is mounted parallel with the axle.
The "traction" bar is a carry over from drag racing. Generally (and in my case) it is a bar that is mounted perpendicular to the axle and runs from the top of the axle forward to some location on the frame or crossmember. Here's a pic or two of mine (there's one on each side):
Mine was custom. Sam's Offroad also sells a one size fits all kind of ladder bar. There have been some reports that these ladder bars are binding during articulation though. Here's a pic of Sam's:
Matt Osburn
Score 1032
osburn is offline
post #7 of 11 Old 04-16-2001, 01:43 AM Thread Starter
SaHaRa JeePeR
thanks man.
how much did the kit cost?
post #8 of 11 Old 04-16-2001, 03:45 PM
osburn
osburn's Avatar
It was a custom job. No kit is available for my setup. Mike Duncan ( http://www.fourxdoctor.com ) built it and a few others just like it. He has to have the Jeep to build it. As you can see, there are no gadgets to allow the bar to lengthen or shorten. So he has to be able to have the Jeep to cycle the suspension to determine the dimensions and location.
Sam's can be purchased at: http://www.samsoffroad.com
Matt Osburn
Score 1032
osburn is offline
post #9 of 11 Old 04-18-2001, 11:31 AM
Cody_91YJ
Osburn...your running alcan springs right??
How did you get ahold of them?
Do they have a website?
Thanks!
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
post #10 of 11 Old 04-18-2001, 02:58 PM
osburn
osburn's Avatar
They have a very primitive website at: http://www.alcanspring.com/
Matt Osburn
Score 1032
osburn is offline
post #11 of 11 Old 04-18-2001, 04:29 PM
Cody_91YJ
Thanks!
I'll check em out
Big Lifts and Axles crogers87 TJ Wrangler Technical Forum 38 07-07-2009 09:54 PM
What is the best.... (suspension lifts and body lifts) RjAndJeep TJ Wrangler Technical Forum 24 06-03-2009 09:33 PM
A run down on suspension lifts.body lifts.spacers mightydog78 TJ Wrangler Technical Forum 5 02-28-2009 12:21 AM
Body lifts/Suspension lifts OffRoadin'Lover TJ Wrangler Technical Forum 4 11-18-2006 02:57 PM
Question(s) about lifts, axles, tires etc?!?!?1 1997ChrisTJ TJ Wrangler Technical Forum 1 10-25-2003 05:24 PM
