Help lift kit - JeepForum.com
post #1 of 5 Old 04-01-2010, 08:29 AM Thread Starter
hubbe
Help lift kit
Hi!
I can't decide with lift kit I want?
My plans are to fit 33" tires
I was thinking either rc 2.5" with 5/8 booms and 1" body lift or rc 4 lift
Which do you think is best?
hubbe is offline
post #2 of 5 Old 04-01-2010, 08:48 AM
YJMonster
If you get a rc 4" you will also need to plan on getting a SYE and and new rear driveshaft.
2000 xj 4.5 Rubicon Express extreme duty(sold)
1988 yj 2.5 RC lift, 1/2 boom shackles- My baby
YJMonster is offline
post #3 of 5 Old 04-01-2010, 10:53 AM
jsahara24
depending on your budget i think you should look into another manufacturer...
however, either setup you mentioned would work though, it depends what your ultimate plan for the jeep is..
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #4 of 5 Old 04-01-2010, 11:18 AM
timatoe
timatoe's Avatar
Originally Posted by jsahara24 View Post
depending on your budget i think you should look into another manufacturer.....
I agree. Like BDS.
Although options may be limited due to your location.
timatoe is online now
post #5 of 5 Old 04-01-2010, 01:16 PM Thread Starter
hubbe
Should add that I plan on putting around 600 USD on a lift
hubbe is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
Motor Mount Lift + Body Lift = Radiator Shroud Placement? tommanns YJ Wrangler Technical Forum 6 01-26-2009 08:04 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
