HELP! leaking oil - clanking sound
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
HELP! leaking oil
new prob. with my 95 yj, i've been notcing a clanking sound every time i hit a bump on the underside of my jeep , feels like its right below my feet under the pedals, a little left... i take a look at evreything, nothing seems loes, or broken... then i notice oil dripping on to my left front leaf spring from the area directly above it.... ( no idea whats above it ) ....
i'll try to post up a picture to better illustrate, but any ideas what that could be ? edit: pics http://img202.echo.cx/img202/5770/10et.jpg http://img202.echo.cx/img202/7027/28vb.jpg http://img202.echo.cx/img202/9916/38fn.jpg UPDATE- the clanking noise was fixed ( broken trac bar ) but im still leaking oil from that same spot daily.... my engine oil is good, all coolants, and i checked my clutch fluid today ( from this - http://www.discountjeepparts.com/catalog/images/products/omix/omix-4636865.jpg ) and it was up to the brim.... any ideas what could be leaking? it only leaks when i drive, and right after i stop driving for a little bit.
#2 |
anybody ? any ideas? im thinking it might be the oil pan jumping around? is that possible ?
#3 |
King of Mac-istan
Check your master cylinder or your clutch linkage. Do you have any leakage from either of those?
#4 |
Also check in the tub at the top of the clutch pedal at the firewall, if I'm seeing the pic right it looks like its leaking from a seam in the tub
95 Wrangler- Stock for now 99 Ram quad cab |
#5 | |
'93 YJ 2.5 Jasper; 5 speed All stock, waiting to be reborn. 6/19/05 ...2" BDS suspension lift...the rebirth has begun!!! ONE NATION, UNDER G O D Support It, or Leave It! |
#6 | |
Nothing to see here...
I had a reall bad 'clank' from the rear and it was a loose lower shock bolt, so now that's one of the first things I check. And is the oil leaking from the tub? or is that splatter? if its splatter, could he have blown out that shock?
#7 |
looks to me like clutch fluid .. have you had to top it up ??
I would check brake and clutch fluid levels .. what ever it is it's leaking from above and looks like it conmes from the tub not engine.
---------------------- Formally 88Jeepster ---------------------- Who's in front ? Ridin' topless again .. sweet !! |
#8 |
i really havent checked much of anything, havent really noticed any diffrence in the clutch...
did check my engine oil and it was low though... |
#9 |
Couple more things to check ..
The tubes going to the evaporator canister located down below the brake booster. If a tube is broken/disconnected and the engine is overfuming there's a chance that oil could drip out a tube. Is your air filter box oily ?? Could oil be dripping out of there ?? Both of the above mean the CCV system isn't working properly .. if that's the case check it out (there's plenty of info on that on this forum .. very common problem).
#10 |
it most likely is cluth fluid.... really havent had a chance to dig in, been working all day..
but any ideas what that clanking sound could be ? its bothering the hell out of me cause i dont see anything thats lose |
#11 |
Clanking sound...
If you're sure it's right below your feet, only when you hit a bump. The only problem I expierenced was the exhuast downpipe would hit the front driveshaft. See if there's any shiny spots on the driveshaft and exhaust manifold. Another shot in the dark but not related to right under your feet, I had my rear trackbar actually break off the mount in the rear. Everytime I hit a bump it would go up, then slam back down on the rear end. Same thing happened to my friend so I don't think it was freak accident. That was the end of the trackbar. I'm just saying don't limit your search to just under the floorpan. Goodluck.
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE 1967 FJ, linked, 350 chevy, 35's, arbs, blah blah... 2002 TJ "If you're not moving ahead, you're falling behind" |
#12 |
UPDATE- the clanking noise was fixed ( broken trac bar ) but im still leaking oil from that same spot daily.... my engine oil is good, all coolants, and i checked my clutch fluid today [IMG]( from this - http://img173.imageshack.us/img173/3161/omix46368650pq.jpg) and it was up to the brim.... any ideas what could be leaking? it only leaks when i drive, and right after i stop driving for a little bit. |
#13 |
Have you tried smelling the fluid, or wiping it to see what color it is?
Motor oil has a distinct smell. Brake fluid is really slimey feeling. Clutch fluid is the same as brake fluid. Have you by any chance filled your Radiator Over-flow bottle too much, or your windshield washer fluid? My YJ would spit fluid in that same area after hitting a real big bump, or being off-road. It was coming out of the washer-fluid reservoir.
Jason T. '05 Saab 9-5 Aero: Black. Turbocharged Swedish goodness '04 WJ:Special Edition. V8, QTII, 2"BB, Bilsteins & 245/75/16" Goodyears '02 WJ:4.7L, Selec-Trac. Totalled 9-12-07. Click to hearKolak 3" exhaust sound clip http://www.cardomain.com/id/MourningWoody |
#14 |
i dont think its motor oil.
its kinda slimey... not much though.... clearish with a greenish tint maybe... its hard to tell cause it just hits the ground and leaf spring |
#15 |
greenish? its antifreeze. i just had that happen over the weekend. i needed a new waterpump. its either the water pump, radiator or the hosees connecting. thats very funny. i could not figure out where the hell this leak was coming from b/c it would stop when i turned the engine off. that leak will only take place when the engine is running because it flows under pressure. it will leak for a lil after u turn the car off b/c its still coolin. but its one of those. get it fixed quick. if u got a pet bring it near it. animals love antifreeze it has a sweet smell to them. but dont let them touch it, the smallest amount will kill them but thats another sure fire test
'89 YJ 4.2L, 6 cyl, 5 spd manual 31" procomp mud terrains, amer rcing blk wheels 1" shackle lift manual a/c!!! [URL=http://pg.photos.yahoo.com/ph/dgoodman111/my_photos]My Jeep[/URL] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
