Help! Jeep wont crank. - Page 2 - JeepForum.com
post #16 of 22 Old 10-11-2013, 07:38 PM Thread Starter
YJ-JoeyC
Originally Posted by Apollo12227 View Post
Are you sure? If I remember correctly you should only have like 3 wires going to the fuel tank... Those 3 looked in-tact.
I'm not home right now, but I think the small crappy quality picture is making it hard to see what I'm showing. Ill post back in a little while with a better picture and how exactly do I check the relays?
YJ-JoeyC is offline
post #17 of 22 Old 10-11-2013, 07:46 PM
Apollo12227
If your horn works, you can swap your horn relay into the other slots... I don't think it is a relay issue, but it is a free way to eliminate them as an issue.
Apollo12227 is offline
post #18 of 22 Old 10-11-2013, 08:07 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
auto shutdown relay maybe, or maybe fuse to computer since the light is off for that
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #19 of 22 Old 10-11-2013, 11:33 PM
DauntlessDad
Check the "Fusible Links" too!
DauntlessDad is offline
post #20 of 22 Old 02-07-2014, 01:45 PM
timduncann
I'm kind of having the same problem right now. I have a 94 yj with the 2.5 5 speed manual and I'm getting lights on my gauges but it won't crank and I can't hear the fuel pump prime like I usually can. And none of the gauges are working either. Any ideas?
timduncann is offline
post #21 of 22 Old 02-07-2014, 03:00 PM
Mark05059
Timduncann start a new thread so that we can help you better.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #22 of 22 Old 02-07-2014, 03:39 PM
timduncann
I did already. It wasnt to long ago
