Help jeep is possessed. electrical failure? - JeepForum.com
post #1 of 8 Old 11-20-2009, 11:43 AM Thread Starter
btn2020
So the pretty stock 89 nuttered I6 has started to act up. A few days ago i would be driving and the radio would flicker off then right back on. It has retained its memory all but once when it did this. At first i thought it was getting wet because it started on rainy days and when i first accelerated. But couple days later it would do it randomly driving down the road. And today the radio would cut off, the blinkers would flash and the wipers would come on for more than one cycle. No set number of times each time. Turning the wiper switch on then back off did not stop it. I am not sure exactly what could cause this. My first guess is a faulty ground? Am I right to assume this and where to look?
Brian Nelson
1989 red stock yj 30in tires
btn2020 is offline
post #2 of 8 Old 11-20-2009, 11:51 AM
yjcrawler
I would definetly check the grounds first, if thats not it maybe some loose wiring?
Soon to be SOA with 14 Bolt SF rear, D44 front and 38's
Early YJ Club, Member # 33
yjcrawler is offline
post #3 of 8 Old 11-20-2009, 11:57 AM
Delta347
I am going to go with, yeah...you need an exorcist
But if you want to be practical - yeah check your grounds. I had a similar issue (not nearly as intense) but my stereo would go on and off and occasionally the head lights would cut out.
It was a rusted out ground somewhere under my dash. routed it to a nice ground terminal I set up for such purposes and its now a happy wire
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #4 of 8 Old 11-22-2009, 12:52 AM Thread Starter
btn2020
checkd the grounds the ones i know of at least any other ideas?
Brian Nelson
btn2020 is offline
post #5 of 8 Old 11-22-2009, 12:59 AM
bigbelman2009
is the connectionto your radio and everything good and tight?
add dielectric grease
bigbelman2009 is offline
post #6 of 8 Old 11-22-2009, 02:21 AM
Machine15825
Usually a faulty ground wouldn't make your wipers come on but rather not work intermittently... but I've seen bad grounds do some crazy ****... I would drop the dash and thoroughly check all wires for bare insulation, melted, etc.... but first check/ recheck all grounds. loosen all grounding terminations clean them and re-tighten. Go from there.
Machine15825 is offline
post #7 of 8 Old 11-22-2009, 03:28 AM
Bgut
2009 JK Wrangler
I would also bend a wire and see if the insulation is cracking. If so you may have to replace some wires.
Bgut is offline
post #8 of 8 Old 11-22-2009, 03:44 AM
Machine15825
You can buy a complete wiring kit for anything from EZ wire for 120 bucks... I rewired my camaro and it was cake.... Time consuming but stupid simple.... Point to ponder if times get too tough... It'd be a great time to upgrade to an HEI dizzy and dump the computer completely since its already nuttered...
Any electrical failure? Slattone JK Wrangler Technical Forum 2 09-04-2009 09:57 AM
electrical failure jboy416 TJ Wrangler Technical Forum 6 04-19-2009 01:53 PM
My Jeep is Possessed - HELP! w8r TJ Wrangler Technical Forum 6 03-25-2009 11:58 AM
Post-Nutter complete electrical failure defmornahan YJ Wrangler Technical Forum 10 11-29-2008 06:45 PM
My Jeep is Possessed.. Heeeelp! :) denwagh YJ Wrangler Technical Forum 4 05-08-2007 03:02 PM
