Help Jeep Not Starting After I Did Throttle Body Swap - JeepForum.com
post #1 of 5 Old 01-30-2010, 06:35 PM Thread Starter
countryboy15
HELP, MY JEEP NOT STARTING AFTER I DID THROTTLE BODY SWAP. iT IS TURNING OVER BUT IT WONT CATCH AND KEEP GOING. riGHT AFTER i DID THE SWAP IT STARTED. tHEN I KILLED IT TO CHANGE THE RADIATOR FLUIDS. aFTER i DID THAT iT STARTED BUT i NOTICED there was a clunking vibration coming from motor. I killed it to add more fluids, but after it didn't start how much more details are needed.
1st jeep= 1991 jeep wrangler 4.0L(wrecked)
2nd jeep= 1991 jeep wrangler 2.5L(ongoing project)
countryboy15 is offline
post #2 of 5 Old 01-30-2010, 07:45 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Did you use the original IAC and TPS sensors in the new TB?
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 5 Old 01-30-2010, 09:19 PM
MJMPC
Check all the things you did and see if you pinched a wire or knocked one off.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 5 Old 01-31-2010, 06:00 AM Thread Starter
countryboy15
I couldn't get the TPS off,(it wasn't until after I put it on there that someone told me you just apply a little heat) but does that really make a difference
post #5 of 5 Old 01-31-2010, 06:19 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Next time - do not use capslock unless you want everything deleted. I doubt that anybody wants to read all that yelling.
Joe Dillard is offline
2.L to 4.0L throttle body swap provinT13 YJ Wrangler Technical Forum 98 03-27-2010 06:01 PM
help '91 jeep wrangler 2.5 not starting after I did the 4.0 throttle body swap countryboy15 YJ Wrangler Technical Forum 0 01-31-2010 06:59 AM
2.5L TJ - Throttle body swap lsakbaetle3r9 TJ Wrangler Technical Forum 38 12-25-2009 07:25 AM
Throttle Body Swap mrcabinet YJ Wrangler Technical Forum 0 09-09-2009 09:27 AM
Throttle body swap mrcabinet TJ Wrangler Technical Forum 0 09-09-2009 09:08 AM
