Help!!! jeep getting flooded when it rains - JeepForum.com
post #1 of 6 Old 11-02-2013, 12:44 PM Thread Starter
Andy1969
Hi guys
My YJ is leaking water in the passenger side (Jeep is UK RHD), it is getting wet behind the passenger seat and on the side of the tub, it is getting very wet. The roof is a factory hard top, I have noticed that there are no seals between the roof and tub, anyone give me any ideas where i should start looking
Cheers guys
"Here in Wales we have special mud with healing properties, so I do my best to get my Jeep covered in it at every opportunity, just to keep it healthy"
Andy1969 is offline
post #2 of 6 Old 11-02-2013, 01:05 PM
Apollo12227
Replace your windshield cowl seal. Replace your possibly non-existant hardtop seals. Two run along the bed rails of the tub. One runs across the top of the windshield frame.
Apollo12227 is offline
post #3 of 6 Old 11-02-2013, 05:24 PM
willawolfe
Cut some drain holes, keep up with the rust.
willawolfe is offline
post #4 of 6 Old 11-02-2013, 07:51 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
Ive read something about the vent things clogging up and that will fill up with water and dump in the cab too.
Then there is this thread, Might help! http://www.jeepforum.com/forum/f12/t...up-how-628941/
-April '14- YJoTM- June '15]
The_Goob is offline
post #5 of 6 Old 11-02-2013, 09:00 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Check the black rubber sock looking thingy hanging next to your battery tray. It is likely packed with mud. Clear it and see if your problem goes away.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #6 of 6 Old 11-03-2013, 09:25 PM
timatoe
timatoe's Avatar
The write up from the FAQ's cover's a large majority of where water can come in. Although I had water coming in through the body seals just behind and below the actual cowl. I was painting / bedlining the entire jeep at the time so I dug out all of the old sealant put new in and coated over it.
timatoe is offline
