Help! Injector issues! - Page 2 - JeepForum.com
post #16 of 17 Old 08-26-2011, 03:11 PM
oldtime_ironman
Far easier to just unhook the batt for 5 mins. This resets the computer and forces it to learn the new setup.
oldtime_ironman is offline
post #17 of 17 Old 08-27-2011, 12:48 AM
mrdeath2000
I fixed my rough idle I had. I think somewhere in my installation or removal of parts i made a hole in my FPR's vacuum hose. Taped it up for now until I hit the parts store tomorrow. Idled like a dream.
In one shot I did all the following mods, so it was down about 1.5 weeks:
New Oem plugs gapped .055
Accel low resistance wires
DUI blue cap/rotor with brass terminals
ford 19# injectors 280150556 (210cc @43.5)
pertronix coil
bored open intake to match gasket
62mm spacer and TB
Fired right up, no problem, ran great, just idled a little bad until I found that leak.
If you changed nothing else but the injectors, try your stock ones again. If that fixes it, try your other 4 from that set. If those don't work, you're more than welcome to try my other 4 injectors. Figure 20 shipped priority usps.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
help! no injector pulse, no current to injector kirkland1625 YJ Wrangler Technical Forum 3 02-25-2012 08:10 PM
Injector Help captjanes TJ Wrangler Technical Forum 3 02-03-2011 10:20 PM
Injector Help J33Pyj YJ Wrangler Technical Forum 13 07-20-2008 12:04 AM
Gas leaking around injector, o-ring or injector itself? hedrinbc TJ Wrangler Technical Forum 8 05-09-2007 09:13 PM
Think it is the injector? Mr. Tobes YJ Wrangler Technical Forum 2 06-04-2006 07:00 PM
