HELP!? (im new) - JeepForum.com
post #1 of 7 Old 10-03-2011, 06:20 AM Thread Starter
chris447
HELP!? (im new)
hey all,
my name is chris, im a new wheeler and decided to join this site, im planning a build and currently in the middle of installing a r/c 4inch lift, i have quite a few questions, also my jeep needs to be able to go down the road (im a weekend warrior so to say) but i want as much flex as possible...
1. do i need my rear trac bar? i cant get the bolt out (seised up or somthing) on the bottom side, making my jeep sag to the drivers side so i planed on cutting it off.
2. where can i find the coiled brake line for drivers side front, it broke right at the backet where it connects to the rubber line.
3. are boomerang shackles worth the money over regular shackles? i planned on going 1.25 inch.
ANY OTHER GOOD ADVICE WOULD BE GREATLY APPRECIATED
im kinda on a tight budget due to buying an engagement ring last friday, but il find a way to do things right
chris447 is offline
post #2 of 7 Old 10-03-2011, 07:10 AM
dadstoy
Welcome to the world of Jeeps.......
1. Ditch the track bar. You want miss it and you will get a better ride.
2. Try Quadratec for the extended brake line kit. You will probably need extended lines with that lift. I went with stock until I was uncomfortable with the stock ones. Looked like they were stretching........
3. Have no personal experience with boomerang shackles.
dadstoy is offline
post #3 of 7 Old 10-03-2011, 07:33 AM
dillonjm
2013 WK
I'll answer the boom question.
The booms help you clear the rear frame brace (when installed correctly) and help prevent spring inversion in the front (once again, when installed correctly).
Personal recommendation, don't go more than 1" lift on shackles.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 7 Old 10-03-2011, 08:06 AM Thread Starter
chris447
thanks, are those brake lines the ones that go all the way? im sure u can picture where i broke it... and also do i need the bolt on bump stop extensions that came with the kit?
chris447 is offline
post #5 of 7 Old 10-03-2011, 08:39 AM
dadstoy
Yes, those brake lines go from your hard line to your calipers. I ran 3 years without extended bump stops, but have them now. Not sure why I put them on since my front axle misses them at full stuff.
dadstoy is offline
post #6 of 7 Old 10-03-2011, 08:50 AM Thread Starter
chris447
ok, i need that steel line that goes into the rubber line... it looks like a coiled steel line... anywhere to get one of those? or any way to make one? we have plenty of stainless tube at work
chris447 is offline
post #7 of 7 Old 10-03-2011, 08:53 AM Thread Starter
chris447
my little steel rainbows i have u bolted to my axle are gonna come off tonight too since they not needed... it doesnt give u much room at all with them
chris447 is offline
