Help Im all muddy!!!!! how to clean? - JeepForum.com
post #1 of 6 Old 03-25-2002, 08:57 PM Thread Starter
bjg
Today was my first outing on my new tires and they are a trillion times better than stock (I bought 31x10.5 Wrangler mtrs) the only problem is my dad is going to kill me when he sees all the mud in the engine bay. What the hell can I do to clean it? Im running out of time. I already powerwashed it but mud is still on the hoses and other tight places. I was a little worried about hitting the distributor and such but I think im OK. Any Ideas or thoughts would be appreciated, thanks, Brandon
95 Wrangler with a 2.5, 31 in mtr's, Looking to go BDS 3.5.
bjg is offline
post #2 of 6 Old 03-25-2002, 11:14 PM
mopar_man
I used to detail vehicles and what we did when we washed engine bays was pretty much just pressure wash anything (including distributor and other electronic stuff). It never hurt but everything we worked on was '94 or newer. What I did with my truck (I had a F*rd at the time) was take some plastic bags and twist ties/elastic bands to cover the distributor and other sensitive parts and went at it with the pressure washer. Started right up without a problem after. Don't be afraid to get close to hoses with the washer but don't get too close to the bags and other stuff that might not like the forceful blast. I cleaned some pretty dirty engine compartments in my time (LOTS of oil field trucks and the odd off-road machine). Sometimes it took some time to not blast stuff real close that I shouldn't have but it paid off in the end with a clean compartment. For some of the more delicate stuff, I needed to make it wet and use a scrub brush to get the dirt off. I don't know if that helps any but just thought I'd let you know how I did it.
1987 Wagoneer
4.0/auto
Fully loaded and totally stock......for now
mopar_man is offline
post #3 of 6 Old 03-25-2002, 11:15 PM
Josh
go to an Autozone or any other similar store and buy some engine degreaser, that should make it look as good as new
1987 Wrangler, mods...currently torn apart, working on new motor, SOA, Dana 300, d44 front, ford 9 rear
Josh is offline
post #4 of 6 Old 03-27-2002, 10:10 AM
jeeping18
id recomend getting SIMPLY GREEN automotive spray bottle at auto-zone and spray it on cold motor, let it sit for 10 min and pressure wash.
works great for me!
1991 YJ
-4.0L I6
- BORLA CAT BACK EXAUST
-2.5 INCH PRO-COMP LIFT
-31X10.50 PRO-COMP MUD'S
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
jeeping18 is offline
post #5 of 6 Old 03-28-2002, 10:42 AM
89 YJ
Ive given up every time i wash it i go into the mud again!
89 YJ Islander, AC,PS, 10 inch lift, 32 BFG MT's, sway quick disconnect, rear track bar quick disconnect, 400 watt 12 speaker cd player for tunes,8000lb warn 8274 with 150 ft cable, and a high lift jack.. Lockers, 35's, webber carb and jacobs ignition comming soon.
89 YJ is offline
post #6 of 6 Old 03-28-2002, 08:10 PM
4wheeler4CJ
4wheeler4CJ's Avatar
Yeh, true, but you wipe your a** every time you S@it, don't you?
4wheeler4CJ is offline
JK Muddy dawnskaybug JK Wrangler Technical Forum 17 06-07-2007 12:14 AM
Muddy top won't come clean RedWrangler04 TJ Wrangler Technical Forum 8 12-03-2006 04:03 AM
Best way to clean muddy seats? JeepinYahoo TJ Wrangler Technical Forum 9 04-08-2006 10:25 AM
Got it muddy! rhelton04 TJ Wrangler Technical Forum 21 02-26-2004 06:01 PM
