HELP - ignition switch removal - Page 2 - JeepForum.com
post #16 of 42 Old 04-26-2008, 10:35 PM Thread Starter
blamejane2
Awesome. Sooooo...is this procedure just somehting you learned the hard way? I mean, how come everything I've read/learned through my research had me removing the steering wheel etc?
Anyway, I can't wait to work on my jeep tomorrow. Wahoooooo. Thanks again Pat!
blamejane2 is offline
post #17 of 42 Old 04-26-2008, 10:47 PM
pat8942
pat8942's Avatar
I've been a mechanic for 40+ years and I learned a thing or two in that time.
I started out knowing nothing and I made my fair share of mistakes, but I listened and learned from the more experienced guys.
Never be afraid to ask questions, thats how we learn.
BTW there is no such thing as a stupid question.
Any mechanic worth his salt will be more than willing to share his knowledge with a greenie.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #18 of 42 Old 04-27-2008, 12:09 AM
timatoe
timatoe's Avatar
Also, the two screws that hold the switch on top of the column should be 7mm head. I didn't drop the column when I replaced mine, but that definately would've made it easier.
timatoe is offline
post #19 of 42 Old 04-27-2008, 08:14 AM Thread Starter
blamejane2
You are the man Pat. Thank you so much for your time and knowledge, which, lucky for all of us, you share so freely.
Valerie
post #20 of 42 Old 04-27-2008, 10:21 AM Thread Starter
blamejane2
Pat, are you around?
I've remove to two bolts, but the steering wheel doesn't move very far. Am I supposed to disconnect the column U-joint? I'm thinking doing so will allow me to pull the column out enough that it will lay on the seat.
post #21 of 42 Old 04-27-2008, 10:35 AM
pat8942
pat8942's Avatar
Loosen the clamp (Bracket) at the bottom of the column and it should drop down.
pat8942 is offline
post #22 of 42 Old 04-27-2008, 10:56 AM Thread Starter
blamejane2
thanks pat, that's exactly what we did. It pulls out a little further (approx 2 inches), but there's some kind of metal piece that's inserted into the column, which doesn't allow it to pull out much further. Do you know what this is? SHould I take a photo?
post #23 of 42 Old 04-27-2008, 11:00 AM
timatoe
timatoe's Avatar
You don't need to take the column all the way out, just drop it down to make it easier to get on top of it.
timatoe is offline
post #24 of 42 Old 04-27-2008, 11:07 AM Thread Starter
blamejane2
yeah, I see what you mean timatoe.
I can get to the switch, but my little fingers are going to have to work hard at removing it.
post #25 of 42 Old 04-27-2008, 11:12 AM
pat8942
pat8942's Avatar
That would help.
If you remove the bolts from the lower bracket it should drop down quite a bit
pat8942 is offline
post #26 of 42 Old 05-20-2013, 08:26 PM
marine_zl
stuck
I've got a 90 yj 5spd and it just didn't start. Solenoid clicked but starter wouldn't turn. I took the whole starter and battery to AutoZone and they're good so I'm sure its the switch. I dropped the column and detached the switch housing from the column. But I can't get the wires disconnected or get the housing up closer to get any leverage. I have taken off part of the dash and left the steering wheel on. What am I doing wrong? Thanks in advance.
marine_zl is offline
post #27 of 42 Old 05-21-2013, 02:41 PM
daviddoughty1
1987 YJ Wrangler
If the solenoid clicks when you turn the key I would have to think the ignition switch is doing its job. Check starter ground
daviddoughty1 is offline
post #28 of 42 Old 05-21-2013, 06:59 PM
marine_zl
still lost
Starter ground is fine. Everything else hooks up right. I finally got to the switch and now I can't figure out what the hell these two metal rods are running down the column
post #29 of 42 Old 05-21-2013, 07:16 PM
daviddoughty1
1987 YJ Wrangler
One on left is actuator for dimmer switch. One on right operates ignition switch I believe.
post #30 of 42 Old 05-21-2013, 07:54 PM
marine_zl
Yep thanks. Problem now is how is the rod supposed to engage the switch. Haynes is no help.
Ignition Switch Removal Crispy8743 TJ Wrangler Technical Forum 9 10-09-2009 07:45 AM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-28-2009 12:02 AM
Could this be an ignition switch? 94laredo YJ Wrangler Technical Forum 27 11-11-2007 08:34 AM
TJ Ignition Switch watsonmcg TJ Wrangler Technical Forum 0 10-13-2007 07:03 PM
Ignition Switch SteveJcoYJ YJ Wrangler Technical Forum 3 04-30-2007 09:21 PM
