HELP - ignition switch removal - JeepForum.com
post #1 of 42 Old 04-26-2008, 03:30 PM Thread Starter
blamejane2
Can someone tell me how i get to the ignition switch on my yj. I have the chilton's, but it on says that the switch is located on the steering column. It says put the key into the off-lock position, unplug the electrical connector, remove bolts and detach switch.
Has anyone done this before...Do I need to remove the steering wheel, etc.?
The manual is very vague, or I'm just missing something. Where's that freakin' switch. The autoparts store closes in 90 minutes, and tomorrow it's closed. Any help would be greatly appreciated!
Thanks
Valerie
blamejane2 is offline
post #2 of 42 Old 04-26-2008, 03:52 PM
ghost183
yes, the steering wheel has to be removed, along with the turn signal assembly and cap, careful though, theres a small circulat retaining clip holding the cap assembly in place, it pops off kinda violently, after you take all that stuff off (turn signal assembly pulled to the side) theres a bolt there that you have to remove to slide the key cylinder off, i dont remember but, i think the key has to be on the run position to slide out
ghost183 is offline
post #3 of 42 Old 04-26-2008, 04:00 PM Thread Starter
blamejane2
Thanks ghost, that certainly helps.
I'm guessing the chilton's manual assumes I'm following some path of steering wheel/column work, cuz as I look backwards through the pages it kind of "flows" that way. Anyway, I've gotta pickup a steering wheel puller as I can't get mine off.
post #4 of 42 Old 04-26-2008, 04:37 PM
blue1989yj
blue1989yj's Avatar
IIRC there is a locking plate under there as well. I beleive I rented the tool at Advanced Auto for that. Someone else can chime in confirm/deny that.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #5 of 42 Old 04-26-2008, 05:14 PM
pat8942
pat8942's Avatar
The book is referring to the ignition switch apparently you mean the ignition lock cylinder.
Thanks
Valerie
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #6 of 42 Old 04-26-2008, 06:40 PM Thread Starter
blamejane2
blue1989YJ: I was just reading about that locking plate, so thanks for mentioning it. I found a small auto parts store open tomorrow, and they will loan the steering wheel puller and hopefully the "special tool" for removing the locking plate. I really hope I can get this done in 1 day as I REALLY want to drive my jeep Monday morning!
Pat: I need to replace the ignition switch as I believe it's the cause of my heater/air cond and radio not working. The fuse for the heater keeps blowing, just as I start the jeep. I get nothing from the radio and the corresponding fuse is fine. Before replacing the ignition switch I'm going to test the continuity, just to be sure I've located the problem. I've read through the manual and it looks like I'll be removing the steering wheel, the turn signal/hazard switches, and the ignition lock cylinder, before I can actually test the ignition switch.
post #7 of 42 Old 04-26-2008, 07:19 PM
kloppk
Whoa!
A little confusion here...
If you are replacing the ignition switch and not the ignition key cylinder then you do NOT need to pull the steering wheel, lock plate, etc.
The actual ignition switch mechanism is mounted to the steering collumn under the dash. It's connect to the ignition key cylinder with a steel rod.
When you turn the key is moves the steel rod that runs along the top of the steering collumn down to actual the switch mounted to the steering collumn under the dash.
kloppk is offline
post #8 of 42 Old 04-26-2008, 07:22 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Two different things here.
What is the issue that is leading you to belive the switch is bad????
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #9 of 42 Old 04-26-2008, 08:25 PM Thread Starter
blamejane2
Whoa is right. Oh man, thanks rusty and kloppk. Well, I stuck my head under the dash earlier and didn't see anything that looked like the switch, but I'll check again.
rusty: Regarding the possible bad switch is the following thread:
http://www.jeepforum.com/forum/f12/heater-fuse-keeps-blowing-550819/
where I describe the problem I'm having with continual blown heater fuse:
I just replaced the blown fuse for my heater. With a new fuse in place I tried the heater, and again nothing...sure enough I've blown another fuse. After installing another fuse I started the jeep and then stopped it (without turning on the heater). I checked and the fuse was blown again, just by starting the jeep.
Does anyone have an ideas where/what I should look at?
post #10 of 42 Old 04-26-2008, 08:36 PM Thread Starter
blamejane2
Basically I wanted to test the continuity of my ignition switch to track down the blown fuse problem. I was trying to figure out how to do this with my chilton's, which was a bit vague on "where" this freakin' part was. I'm sure it's my fault for being a total noob.
post #11 of 42 Old 04-26-2008, 08:40 PM
pat8942
pat8942's Avatar
The best way to get at the switch is to take the two bolts out that hold the column to the dash and let the steering wheel rest on the seat and it makes access to the switch easy.
pat8942 is offline
post #12 of 42 Old 04-26-2008, 09:01 PM Thread Starter
blamejane2
Thanks so much Pat. If it turns out my switch is bad, then will I have to remove the key cylinder (via steering wheel, etc) in order to replace the ignition switch?
post #13 of 42 Old 04-26-2008, 09:14 PM
pat8942
pat8942's Avatar
No you won't it will just lift off the wire that actuates it from the key.
Once you get it to where you can see the switch it will be obvious how it comes off.
pat8942 is offline
post #14 of 42 Old 04-26-2008, 09:26 PM Thread Starter
blamejane2
Thanks Pat. You mention...
Are these the bolts you're talking about:
post #15 of 42 Old 04-26-2008, 09:30 PM
pat8942
pat8942's Avatar
Yup that's them.
pat8942 is offline
Ignition Switch Removal Crispy8743 TJ Wrangler Technical Forum 9 10-09-2009 06:45 AM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
Could this be an ignition switch? 94laredo YJ Wrangler Technical Forum 27 11-11-2007 07:34 AM
TJ Ignition Switch watsonmcg TJ Wrangler Technical Forum 0 10-13-2007 06:03 PM
Ignition Switch SteveJcoYJ YJ Wrangler Technical Forum 3 04-30-2007 08:21 PM
