Help identifying random things in engine bay... - Page 2 - JeepForum.com
post #16 of 16 Old 08-20-2011, 11:58 PM
JSahara00
Check sending unit by pulling off the wire and connecting to negative battery terminal then start the jeep and if it reads zero then sender is deal if it still goes up you have some more wires to clean up and fix
00 TJ, OME shocks, all currie control arm, OME steering damper, Brown dog MML, VIAIR OBA with 2 quick disconnects at the doors, jks quick discos, Kolak exhaust, 30 spline D30 w/ ARB and 4:56, 8.8 w/ super 88 and ARB, home made F/R bumpers and tire carrier,OME zj front springs and OME Lj rear springs, CB w/ firestick, DIY highline fenders/hood, 35 pro comp mud terrains, cragar soft 8s .. .
95 XJ 4.0 4x4 Auto, V8 ZJ steering linkage
JSahara00 is offline
Need help Identifying engine honiglandscapes YJ Wrangler Technical Forum 4 02-21-2009 11:07 AM
Need help identifying bolts!! -- and other random help needed! MikeyJ YJ Wrangler Technical Forum 4 01-12-2009 09:35 AM
Identifying my engine... flipmobile YJ Wrangler Technical Forum 4 04-19-2008 02:54 PM
identifying engine help Dwayne96 TJ Wrangler Technical Forum 5 04-12-2008 02:23 PM
Help identifying sensor and some random questions... 89 YJ 2.5L - Pictures Included Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-15-2006 08:41 AM
