Help identifying random things in engine bay... - JeepForum.com
post #1 of 16 Old 08-18-2011, 09:28 PM Thread Starter
exigex
So I'm trying to clean up the mess the previous owner left this YJ in.
Here are some random wires, hose, connectors, and maybe sensors that are not connected and I don't know what they are.
Any one know what they are?
Some of them might just be extra wires and stuff that I can get rid of, I just don't know..
Thanks
exigex is offline
post #2 of 16 Old 08-18-2011, 09:40 PM
oldtime_ironman
I think the last pic is your 4WD vacuum harness.
oldtime_ironman is offline
post #3 of 16 Old 08-18-2011, 09:41 PM
dancytron
Third picture is the sensor that turns the 4wd light on.
The last picture is the vacuum lines that control the CAD (vacuum motor) that locks the front axle when you are in 4wd. Red line with the check valve is the source of vacuum. Blue line is a vent and should be open or have a filter. Other two should run down to the axle.
Do you have a posilok or solid front axle? If you do, then that stuff is extra and you can take it out.
dancytron is offline
post #4 of 16 Old 08-18-2011, 11:09 PM
jth0033
1987 YJ Wrangler
Originally Posted by exigex View Post
I was always told this is if your Jeep came with a hardtop with a rear wiper, there would be another windshield fluid bottle
Looks like the plug from A/C...
Sensor for 4wd light
Coil
Vacuum lines for front vacuum motor
Hope this helps some.
jth0033 is offline
post #5 of 16 Old 08-18-2011, 11:41 PM
Xpress
The last pic is the vacuum lines. The red line is what plugs into the manifold, and the bit on the end is supposed to be on the blue line. It's the vacuum check line. The yellow lines should run down to the shift motor, then one line should run back up to the 4WD sensor (blue thing in the 3rd pic). The green line is what disengages the shift motor to disengage the axle.
I have the same plug in the 2nd pic just floating around too. I guess it was for AC?
All about that unibody life.
Xpress is offline
post #6 of 16 Old 08-19-2011, 09:33 AM
JSahara00
He doesnt know much about this thing and the PO was no help whatsoever he kept telling us its a 4 cylinder.. so any help to get this thing back into proper running order is greatly appreciated.. did they have those funny vaccum disconnect front d30 in these? is that what that red line is for?
00 TJ, OME shocks, all currie control arm, OME steering damper, Brown dog MML, VIAIR OBA with 2 quick disconnects at the doors, jks quick discos, Kolak exhaust, 30 spline D30 w/ ARB and 4:56, 8.8 w/ super 88 and ARB, home made F/R bumpers and tire carrier,OME zj front springs and OME Lj rear springs, CB w/ firestick, DIY highline fenders/hood, 35 pro comp mud terrains, cragar soft 8s .. .
95 XJ 4.0 4x4 Auto, V8 ZJ steering linkage
JSahara00 is offline
post #7 of 16 Old 08-19-2011, 09:51 AM
dtn8tr
Yes there is a vac disconnect on your YJ unless it has been modded with a TJ/XJ shaft.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #8 of 16 Old 08-19-2011, 10:41 AM
oldtime_ironman
Yeah they had the vacuum disconnect. That's what those lines are in the last pic.
post #9 of 16 Old 08-19-2011, 10:42 AM
JSahara00
thanks that will be helpful... these yj's are wierd compared to the tj im used to hahahaha i am a fan of the leaf springs though..
post #10 of 16 Old 08-19-2011, 10:56 AM
jth0033
1987 YJ Wrangler
Check out the second post here for a vacuum diagram.
http://www.jeepforum.com/forum/f12/f...y-here-451154/
jth0033 is offline
post #11 of 16 Old 08-19-2011, 05:12 PM
tslroper
In the fourth pic that loose wire on your coil is supposed to connect to the condenser (the little canister on the coil bracket) to prevent the ignition system from causing static on your radio.
1990 YJ Islander, 4.2L MC2100 DUI HEI, 2.5" RE lift, 31x10.50 DuraTracs, HandenFab rear bumper / swing-out, Tough Terrain
off-road camp trailer.
Build thread: http://www.jeepforum.com/forum/f22/tys-yj-build-1502554/
tslroper is offline
post #12 of 16 Old 08-19-2011, 07:33 PM Thread Starter
exigex
cool thanks for the info, hopefully get a lot of work done this weekend.
exigex is offline
post #13 of 16 Old 08-19-2011, 09:04 PM
JSahara00
Hey justin have fun in two weeks I can come up and help you.. ill bring the fluids
post #14 of 16 Old 08-20-2011, 07:40 PM Thread Starter
exigex
****s all good, cleaned up the hoses and wiring and installed new starter and it starts and runs pretty nicely except the oil pressure gauge still doesn't work (just goes all the way as soon as it is turned on and stays there) need to look into that.
then steering shaft, e-brake, horn, oil pan gasket, and all fluids...and it will be ready for the winter.
exigex is offline
post #15 of 16 Old 08-20-2011, 10:58 PM
tslroper
Replace the oil pressure sending unit and you'll get a proper reading. Theyre cheap and fail often.
tslroper is offline
Need help Identifying engine honiglandscapes YJ Wrangler Technical Forum 4 02-21-2009 10:07 AM
Need help identifying bolts!! -- and other random help needed! MikeyJ YJ Wrangler Technical Forum 4 01-12-2009 08:35 AM
Identifying my engine... flipmobile YJ Wrangler Technical Forum 4 04-19-2008 01:54 PM
identifying engine help Dwayne96 TJ Wrangler Technical Forum 5 04-12-2008 01:23 PM
Help identifying sensor and some random questions... 89 YJ 2.5L - Pictures Included Big-n-Broke-YJ YJ Wrangler Technical Forum 4 02-15-2006 07:41 AM
