Help! I can't see! Headlights OUT! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Help! I can't see! Headlights OUT!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Wrangler WeatherstrippingJeep Wrangler Exhaust Manifold
Unread 03-30-2002, 12:12 AM   #1
achilles99
Well, I just had a very scary situation in the "new" Jeep. I just purchased a 92 Wrangler, and for some reason the headlights stopped working. The bulbs aren't blown, and the parking lights still work. Anyone have an idea? I've done a little research, and the most I've been able to dig up is that the headlight switch may be broken. Any truth to this?
Oddly enough, my battery died before this happened. After I had a friend jump it, I noticed the headlights were out. HELP!
achilles99 is offline   Reply With Quote Quick reply to this message
Unread 03-30-2002, 06:32 AM   #2
RCHavok797
I had this happen to me once. I just flicked the high beam switch and everything worked fine. It has never happened to me again.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline   Reply With Quote Quick reply to this message
Unread 03-30-2002, 08:24 AM   #3
axle
i had this problem once before also. it started out that when i turned my headlights on they wouldn't come on until i actually flicked the dimmer switch. this went on (on occasion) for about a month until one night they didn't work at all. i replaced the dimmer switch and it took care of the problem. hope this helps
axle is offline   Reply With Quote Quick reply to this message
Unread 03-30-2002, 11:27 PM   #4
achilles99
Thank you so much! The headlight hi beam trick worked. I guess the switch has some kind of automatic breaker to it? Anyhow, hopefully it won't happen again. But, just in case... now I know!
