Help, I can't figure this out - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Help, I can't figure this out
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-03-2011, 11:10 AM   #1
puddlejumpinzx
When I put the jeep in 4wd, it leaks trans fluid. Only when in 4wd. Its an ax-5. which seal is it that I need to look at getting and which trans fluid. Part numbers are appreciated as well. Thanks
puddlejumpinzx is offline   Reply With Quote Quick reply to this message
Unread 12-03-2011, 11:16 AM   #2
johnny27030
Im confused? Do you have an automatic? Manual? Are you sure its the transmission leaking? Could it be the transfer case? In 4wd your output shaft to the front diff would be spinning, and thats the only thing that makes any sense to me?
And help us help you, fill out your information on your profile. We have no idea what you are working with.
johnny27030 is offline   Reply With Quote Quick reply to this message
Unread 12-03-2011, 11:52 AM   #3
mrmud4x4
if it's tranny fluid, in 4wd, sounds like front drive shaft transfer case seal would be first place I'd look....get a flashlight and take a peak
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline   Reply With Quote Quick reply to this message
Unread 12-03-2011, 11:55 AM   #4
NonRubicon
^ The AX-5 is a manual transmission, typically paired up with the 4cyl.
How have you determined that it only leaks in 4WD? Where are you seeing fluid leak or accumulate?
NonRubicon is offline   Reply With Quote Quick reply to this message
Unread 12-03-2011, 12:01 PM   #5
puddlejumpinzx
It is a manual. I've driven it in 2wd and it doesnt leak anywhere, I drive on pavement, and its dry. When I put it in four and went up an incline, it leaked probably half a quart (when I drove it up on a rollback). So the fluid only leaks when engaged. I believe it is the transfer case seal as well. The tranfer case uses tranny fluid right?
Unread 12-03-2011, 12:08 PM   #6
mrmud4x4
I had mine rebuilt/with heavy duty chain, and when I pulled my rear drive shaft to put in a new u-joint, tranny fluid came out....so that is what they put in it....tranny fluid.
I have synhcromesh gear oil in my ax-15.
If you can get a light on the lower portion of the front drive shaft seal...and get your eyeballs on it....should be able to tell if it's been leaking.
ax-5 , tranny problem , transfer case leak , transmission
