Help! I can't see! Headlights OUT! - JeepForum.com
post #1 of 4 Old 03-30-2002, 12:12 AM Thread Starter
achilles99
Well, I just had a very scary situation in the "new" Jeep. I just purchased a 92 Wrangler, and for some reason the headlights stopped working. The bulbs aren't blown, and the parking lights still work. Anyone have an idea? I've done a little research, and the most I've been able to dig up is that the headlight switch may be broken. Any truth to this?
Oddly enough, my battery died before this happened. After I had a friend jump it, I noticed the headlights were out. HELP!
achilles99 is offline
post #2 of 4 Old 03-30-2002, 06:32 AM
RCHavok797
RCHavok797's Avatar
I had this happen to me once. I just flicked the high beam switch and everything worked fine. It has never happened to me again.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 4 Old 03-30-2002, 08:24 AM
axle
i had this problem once before also. it started out that when i turned my headlights on they wouldn't come on until i actually flicked the dimmer switch. this went on (on occasion) for about a month until one night they didn't work at all. i replaced the dimmer switch and it took care of the problem. hope this helps
axle is offline
post #4 of 4 Old 03-30-2002, 11:27 PM Thread Starter
achilles99
Thank you so much! The headlight hi beam trick worked. I guess the switch has some kind of automatic breaker to it? Anyhow, hopefully it won't happen again. But, just in case... now I know!
Headlights going out JFox YJ Wrangler Technical Forum 2 09-19-2009 05:37 AM
headlights come on... and go out huckster YJ Wrangler Technical Forum 8 12-09-2008 07:22 PM
Headlights go on, radio goes off. Headlights off, radio back on gary1 YJ Wrangler Technical Forum 10 10-29-2008 09:07 PM
IPF headlights kurt'smoneypit TJ Wrangler Technical Forum 48 03-16-2007 09:12 PM
Headlights sxmp YJ Wrangler Technical Forum 17 01-13-2005 09:24 PM
